Hand cut dovetails: getting worse not better
Brian In Dawson Creek
>This is my first attempt using the Rob Cosman�s method by cutting the tails first and then scribing a line from the tails to mark the pins. The first attempt was acceptable, barely. The wood was Birch to Birch.
The instructional DVD says to cut the pins on the waste side of the line but split the line with the saw. So now on the third and this is the fourth attempt all with the same results, if I cut any where�s near the line I get huge gaps, so I�m now cutting well away of the line and pare down to a fit (a lot of work). In the photos you can still see the scribe marks (I started planing them off and then realized I needed them for the photos.) I shouldn�t have to pare this much so all I can think of is that my marking or scribing is to fault, I tried small a jackknife, an exacto knife, a striking knife, all with the same result. Kind of getting frustrated as I not sure how to fix this so I can cut to the line as per the instruction.
Hope someone can put me on the right track.
Thanks
Fourth attempt with 7/16 thick willow
