Help -- starting motor trips circuit breaker
wilbur
>I have a dust collector with a 1.5 HP motor on a 120V 20 amp circuit. By my calculations, 1.5 hp should draw about 13 amps, give or take. (I know this information is on the motor badge, but I forgot to look at it before I left for work today.)
The thing is, when I turn the dust collector on, it trips the circuit breaker pretty consistently. If I reset the circuit breaker and restart the dust collector, it runs just fine then. My guess is that the current draw from the starting capacitors in the motor if they are "cold" is causing this to happen.
Is there an easy fix for this, and should I be worried about continuing to run the motor?
