Unisaw Startup Jolt
Tim Jones
>I recently got a 36-R31x, the 3 horse single phase Unisaw, but was disappointed to see it jolt on startup. The jolt is not drastic, but it definitely will knock over a nickle on edge. You can plainly see the table jiggle a bit. It is smooth after is is up to speed.
I adjusted the belts, took the play out of the elevating shaft via the rear collar, but there is still significant play in the worm gear to rack elevation- I can wiggle the motor about 3/16th, and this movement (all in the worm/rack elevation gears) cannot be eliminated. If I wedge a board between the motor and cabinet to eliminate this slop, the saw starts up very smoothly, so it definitely is this elevation play causing the startup vibration, not a loose arbor or the belts. I spoke with a delta tech who said the that newer high torque motors cause this and it is a normal condition.
Do all recent unisaws have this startup jolt?????
