Grinder mod - Jacobs chuck?
Mike Schwing from Md.
>How would you go about modifying a standard benchtop grinder (Woodcraft slow speed version) to accept a standard 3 jaw Jacob's chuck on one side? It would be SERIOUSLY convenient for me for various power carving accessories I use until I get another lathe that will accept a drill chuck. Damned if I can think of a way to successfully do this. The only chucks I can find are all MT types, as should probably be. Still, there's got to be some way to do this safely.
Even with a motor/shaft/pulley system I still can't find the parts to do this, not sure I really know what to look for. Thanks for your help.
Re: Grinder mod - Jacobs chuck?
dwr
>Mike,
Look for a shaft adapter that will take a MT to a standard diameter (I think I have seen them in some of the Machine Shop mags and web sites.) Some have a threaded end for a draw bar and can be used in a collet chuck. If the threaded end does not match your grinder, you can cobble one together using a small section of all thread and nuts.
Re: Grinder mod - Jacobs chuck? *LINK*
Denis Ch�nard, Orl�ans, Ont.
>Would this do?
DC
LV chuck and adapters
>Mike I'd have to dig through my catalogs but I'm sure there is a way. I know that woodworkers supply has a flex shaft with a chuck on the end. My friend made an adaptor to go from the grinder to the 1/4" shank on the flex shaft. He uses this for rough carving because it has a lot of power.
You can buy chucks that have 1/2" x13 thread. It would be easy to make an adaptor to go from you grinder to 1/2" thread. I haven't had time to learn to do threads on my new metal lathe or I'd offer to build one for you. My friends at Bestwoodtools would probably build one.
Thank you all, yes Denis
>That would work wonderfully! As many times as I've been through the LV catalogs I can't believe I didn't recall that, but I didn't. Thanks again.
Phil Joines Krum,Tx
>MSC has adapters in various sizes. I use a bunch of them to mount wire and buffing wheels and a drill chuck on a 1/4 HP motor. They also have chucks for threaded shafts.
If you go this way make sure the arbor and chuck threads both have the same "hand".
The screws in the adapters will trash the threads on your grinder. Motors aren't hard to find cheap. Mine is an old (oil cap bearings) open frame type. I haven't had any problems with stuff getting in it.
Motor Arbors
George (Oxford, NC)
>Mike -
If I understand your post correctly, you have a lathe that takes MT. If so why not just get one of these?
George
http://www.woodcraft.com/family.aspx?familyid=3975&productid=142553
>Mike, I have one of hose grinders also. I have not looked at it, but they usually have RH threads on one end and LH threads on the other. Check yours out and be sure you want to mount the chuck on the RH End.
Also, I use my grinder very lightly, not much heavy grinding, but I have noticed it slows down quite easily when a little pressure is applied. You might want to check out how much power you really have and see if that would suite you for your chuck.
I have not looked, but I would have thought people like McMaster Carr would have all kinds of adapters and chucks.
