Working With MDO Plywood
John McGaw
>For the first time ever I'm doing a project with MDO. I figured that since it was paint-grade to begin with and having no grain to conceal I would be ahead of the game using it. This project, a low, wide console (57" X 12-1/4" X 17") to hold video equipment, will be a warmup for building a wall of paint-grade bookshelves about 16 feet long in my library.
One thing that has be just a bit concerned is that the MDO I came up with is pre-primed and this may affect the glue joints a bit. I intend to make the top-end joints as biscuit-reinforced miters since they will be quite visible. All of the other structural joints can be dadoes and rebates. The front and rear edges of the sheetgoods will be covered with a 3/4" X 3/4" strip of hardwood covering the raw plywood edges. The strips will be set apart from the structure by a shallow groove creating a bit of a shadow line (and probably a dust catcher). The MDO will be painted gloss black. The hardwood (probably maple) will be given a rubbed oil finish.
I'd appreciate any tips anyone can give me about working with this material. I don't have any drawings to share since, as always, I work entirely from a mental image (seems I never learn but it does keep me on my toes).
Thanks.
Re: Working With MDO Plywood
>John, you haven't mentioned what the "overlay" material is but your mention of "no grain" leads me to think you have MD"F" instead. MDO will have a veneer on one but usually both sides which can be any wood depending on what you buy.
Since you're talking book shelves, you should know that MDF (or "O") needs to be supported every 24" in any direction or it will sag. Put books or other weighty objects on it and it will be worse yet. Personally, I would not use it for a bookshelf, but others may disagree.
I've made a number of pieces from MDF, and PVA glue (Titebond) works quite well so long as you remember that the edges are like a sponge and will wick glue (or paint) away from the joint unless pre-sealed. If you don't control that absorbtion, your glue joint will be "starved" and weak. If you use bisquits, make sure that you cut your slots dead center and allow plenty of time for the joints to fully dry before further finishing. MDF will "telegraph" the bisquits' shapes to the surface otherwise, and you'll have ghost footballs showing in your finish, especially on a painted surface. I would not use bisquits in anything less than 3/4" material for the same reason.
I've had good success with black and white lacquer on MDF so long as the surface was glue sized first. You can buy prepared sizing or, like me, make your own. I used good old white "school glue" mixed with black waterbased dye stain (or white tempra pigment) to about the consistency of low-fat milk, applied in 2 coats about 8 hours apart to give the glue time to penetrate and then dry and seal the fibers. A third coat was then applied only to dull areas. Lightly sand the coats with 320 grit ro remove any nubbies or raised fibers and get an even sheen on the materials. Again, resiz any dull spots and sand smooth before the lacquer.
Hope this helps.
mm
PS
>I still use your polygon calculator from back on the Pond |;-}}}
mm
John, you're talking about
Jim in Houston
>that exterior plywood product with the paper overlay they use for signage right? Using is shouldn't differ dramatically from any other high grade plywood I should think, and all the normal rules for using veneer core plywood would apply. Haven't used it myself yet, but I've heard good things about it's stability and flatness in particular. Keep us updates there are lots here who can benefit from your experiences.
Oops!
>Kind of went down the wrong path there, in that Jim's post reminded me about the exterior stuff which is the reverse of the MDO I referred to; multi-ply veneer-core center with an MDF outer layer on one of both sides.
Duh!!! [sorry]
Use it just like any other plywood, but you'll still need a coat or two of siz if you're applying a thin finish like lacquer.
mm
Jesper, Denmark
Jesper, Denmark
>Don't worry. The MDO (Medium density (fibreboard) overlay) plywood works just as ordinary plywood. The overlay is not primed, it is a thin sheet of MDF bonded with the plywood.
John McGaw
>No. This is real plywood -- seven ply "furniture grade" but the two face layers, instead of being wood, is an MDF-type material. This gives a super-smooth paintable surface with no grain to worry about hiding under the paint. The strength should be equivalent to any good 3/4" ply. The full name is "Medium Density Overlay". I understand that it was originally made for use as a sign substrate but that may be apocryphal.
I actually have thought about making parts of my bookshelves from 3/4" MDF, that being far cheaper than the $72 wholesale the MDO costs. And the vendor actually has MDF already ripped into precise 12" widths which might be adaptable for the verticals. I would not use it for the shelves though, even though I will be keeping the spans there to ~30" since I know how saggy MDF is.
John McGaw
>Actually, the material I bought really is primed in white -- very smooth and slick which might need a touch of very fine sanding before painting I think. It is clear from the bit of overspray on the edge laminations that it really is a sprayed primer coat though. I don't think that there should be very much strength loss from the primer as long as I glue up only freshly-sawn edges. I am starting to think that the biggest drawback might be the $72 wholesale cost per sheet. My 16 feet (call it 5m) of library shelves will use up at least 7 sheets the way I figure it. Ouch...
Ron Hildreth, Alta, Iowa
>John,
Curious- Why use MDO when cabinet grade ply is, around here anyway, about 2/3rds the cost?
MDO is used for signage (I work for the Iowa DOT). It's also referred to as marine grade plywood.
Ron in Iowa
John McGaw
>Basically, I was looking for something that would absolutely not have any grain to show through and which would require minimal painting effort. I have yet to manage to get a really smooth painted surface with regular maple or birch faced plywood. I guess if I were using milk paint such as I use on rustic "Shakerish" pieces the grain wouldn't be a problem but I'm looking for a glossy surface. And maybe if I had an HVLP sprayer or even a regular spray rig it might not be such a problem but the only spray I have is one of the Wagner noisemakers and that is probably worse than no sprayer at all in this case.
I have a source where I could get what they call "shop grade" plywood at quite reasonable prices. Sometimes it is a bit irregular, has the wrong veneer showing (I bought two pieces of 7/8" with what looks bad poplar on one face and relatively decent oak on the other) or might have a small lump somewhere. But at half price or less it isn't bad if you are willing to work around the flaws and oddities.
And, frankly, I was really curious about the stuff if truth must be told.
Interesting abreviations.
Gary Camp, Bend, Oregon
>It is interesting to me to hear the different descriptions of materials for the same set of letters. Around here if you ask for MDO (medium density overlay) you will be (or should be) asked if you want one or two sides good. You will be given veneer core plywood with a smooth resin impregnated paper covering. As Ron said it's primary use seems to be signage, I break down 30-40 1/2" sheets a year for our sign guy. I actually use a fair bit of it my self for shelves or countertop substrate that will be in a potentialy wet environment. Like bathroom counters, bar counters, and commercial kitchen areas. I have had too many lam covered counters draw moisture an swell. At some point any flat surface in a ski area is going to have wet gear placed on it, and on 10,000 ski day there is always water standing on the bathroom counters. Interestingly here, 3/4 is not that much more expensive than 1/2". 1/2 is less than $50 a sheet. As a bit of a side note, I built a "tool" box for we truck out of 3/4 MDO 4 years ago, I never got around to painting it, it has been out in the weather for 4 years with now finish, and except for minor water staining on the paper surface it is as sound as the day I built it.
glc
Oh yeah.
>I have never seen the stuff called MDO with the MDF outer layer. For me the would negate the basic reason I use it, EXTREME water resistance, the flat with surface is a very close second reason for laminate substrate or paint substrate.
glc
Shouldn't be a problem
>Primed MDO is just that, MDO with a curtain-coated primer on it. The construction of the board itself is the same -- a phenolic impregnated backer on both faces of a very good quality, usually softwood, VC plywood. The MDO I have used always had a golden colored facing material; I never used pre-primed stock. It is extremely weather resistant. I had an unpainted MDO facing on an exterior door on my old shop and it showed no signs of structural breakdown after over 15 years of exposure.
Regarding the joinery and the primer, I wouldn't worry about it. It won't affect the miter joints since all you have is ply-to-ply contact, and the rabbets and dados aren't intrinsically strong joints anyhow. If you want to get the last little bit of glue surface, you could swat the last 1/4" with a scraper to get rid of the primer.
I agree with your choice of materials, although MDF might have served just as well in this case, with higher weight and lower cost.
