Getting there... but?
>When I was back in the big city, I used my shavings and sawdust as mulch by the side of the house. SWMBO has suggested that I not do this with the long shavings. The last time I tried shredding the shavings in the shredder part of my chipper/shredder, it didn't work that well. The amount of shavings (still increasing) are such that putting them through the chipper part would be very time consuming. Not to mention the fact that there are only two small blades doing the "chipping".
Any suggestions as to how to chop my shavings finer? I'd even use the chipper/shredder if ya'll think that would work. I'd even breakdown and buy new flails and blades.
Re: Getting there... but?
A lawnmower?
Tom Pilsbury
>That's what I use to shred leaves. I rake them into a few small piles, set the mower to its lowest setting and run through them. Might work with your wood shavings if they're dry enough.
Kevin Adams
>JL--
I'm fortunate that I have lots of woods around me, so I can use my shavings as mulch. They also make a heck of a good fire starter in our outdoor fire pit. The funny thing I wanted to mention is that the first time my M-I-L saw the shavings, she was intrigued on how she could use them in her craft projects. She actually uses the real long strips (plane shavings are better since they are thinner than coming off the drawknife) as ribbon on packages! I sent her a whole box of shavings one time and I think she was selling it to friends!
BTW, those are some nice spindles you have there.
Kevin
Re: A lawnmower?
SteveM
>Especialy if you've got the " mulcher " door / chute you can close. Couple passes and the stuff is gone !
Re: I'll give it a shot.
>OK, I'll wait for them to dry a bit a try a couple passes with the mower. I've got the plug to make it a mulcher only.
Durn! I had hoped never to have to use it again :). I "shortened" my grass since I've moved up here, but with the slopes in my yard, I have to use a weed whacker.
Ron Hildreth, Alta, Iowa
>Try a paper shredder--NNAAA, just kidding!
Ron in Iowa
Larry Clinton
>JL, I too have some problems getting rid of all my sawdust - we use it as mulch as does my son and some friends - still have a pretty big pile. However, I refrain from putting any against or near the foundation of the house. I have heard and read that you should never do that as termites love the stuff and putting a pile next to the sill plate is just sending an invitation to invade your home. This is all second hand knowledge but the risk isn't worth the gain of getting rid of the excess. I can put the stuff in garbage bags and let the city take it where I'm located.
JohnKJordan in East TN
>Might be good animal bedding, if it does not contain walnut. Otherwise, I'd probably pile and burn, perhaps add the ashes to compost.
Stephen Kirk in Quakertown, PA
>I don't have long shavings, but I use mine for animal bedding and firestarting material. Fine stuff gets mixed in with composting.
As for chopping it, lawnmower doesn't sound to bad. I don't rake leaves here, just mulch them down in the fall.
I'll bet you the chip shredder would handle them nicely (oh, and I'm trying to break free the horrible rusted flails on mine right now, then maybe figure out why it hemorrhaged oil in my yard the other day)
