Question for a WC website guru
Ron Hildreth, Alta, Iowa
>Dan, Ellis, anybody----
I've noticed that as I read messages and scroll further down on this page, the messages are no longer in the same order they were posted as. PLEASE tell me it's not my computer! It's not a big deal, just that inquiring minds want to know!
Thanks---
Ron in Iowa
Re: Question for a WC website guru
Dan Donaldson
>How do you have your preferences setup? Depending on how you have them configured, you may get some newer ones apparently out of sequence. Usually, if you click on one of them, you will see the complete thread where they came from.
>Dan,
I can bring up the original message or any of the responses, and I'll see a complete list of all the responses at the bottom. It's just on the main message board, nearly at the bottom as I scroll down, that the messages start getting out of sequence. The only setting I changed from default was "no frames". Wonder if that has something to do with it. It's really not a big thing, unless your looking for something and know what message group it was in.
Ron in Iowa
David Yoho
>Ron, not to worry, it does the same thing on mine - and always has. As the messages head toward the bottom of the list, they tend to fragment before moving off the page. Check your Preferences and try a different setting. It may make a difference.
David
Al Stokka - Cambridge, Iowa
>Ron,
I think what you are seeing is related to the number of days view you set for your preference. If set for, say four days, near the older part of the message list older posts drop out and your view is left with the newer posts...often hanging on the list with no "parent." If you were to change your preference to five days, you'd likely see the other posts as well. That's why the apparently unattached posts appear mostly at the bottom (or top, again depending upon your preference settings) of the message list.
Al
Here's what's going on...
>... and no, it isn't your computer or your frames setting. The messageboard displays all messages posted within the past X days (default is four days), so that's what you see. If they are in response to threads posted earlier, they show up as orphans. You have to open them to see the entire thread that they are a part of. The shorter the time frame, the more jumbled the messages will appear. (Try setting your prefs to 2 days if you really want to see a lot of orphans.) The flip side is that the longer the time frame setting, the less likely that people are still posting replies to a particular thread. If you change your preferences to, say, 7 days, it will probably clean things up nicely.
It's just a quirk of our boards and always has been. I know it can be disorienting. Sorry about that.
>Thank,Al!
I think you might be right! I'll change my setting and try that. Like I said in my post to Dan, only time it really gets fustrating is if you're looking for something and at least partially remember the familiar posts around it.
Thanks to everyone else, too! If this doesn't work, I'll start down the list!
Ron in Iowa
I Feel Sorry For Orphans! Thanks Ellis!
