OT: Cleaning concrete floors for painting *LINK*
John in Calgary
>I recently did a search on here and found the post below describing how to lift oil stains out of concrete prior to applying a two part Epoxy garage floor paint. I wanted to thank Forrest for the detailed post (although I didn't follow it exactly, that has more to do with my lagging memory than anything, and since my oil stains were more droplets than stains, I'm pretty sure the way I did it will work fine) and to suggest on small improvement that I came up with:
Instead of using your shoes to grind the floor dry into the concrete, I bought a drywall pole sander and some 80 grit drywall screen and used that to work away at the process. It worked great - the 80 grit screen ground the floor dry up into the concrete quite well. I still made sure that I ground away at it until I worked up a sweat (hm, is it supposed to be a lubricant between the floor dry and the concrete or is that just a measure of when to stop?).
Anyways, thanks again.
John
Forrest Addy's Oil Removal Magic
