What Kind of cutter is this?
>I found this in my "bit" drawer and have no idea where it came from. It has a half inch shank and is about 3 1/4" long. the cutter part is 1 1/4" long and 5/8" in diameter. There are four spiral flutes. It is somewhat sharp, but not what I would call keen. It appears to be "up cutting". On it it says "5/8-HS" and "Yugoslavia". There is a cross slot int he shaft as if it could be clicked or lock into the shaft of the machine.
Anyone recognise it? High speed or low speed? Metal working or woodworking? Should I slap it into a router and give it a try or would that just set the place on fire?
Re: What Kind of cutter is this?
Dale Lenz
Dale Lenz
>Sounds like an end mill bit. You say it's 1/2" bit, then you describe it as having a 5/8" dia. could be milled down I guess. Not sure if you can secure an end mill with that flat spot thingy in a router or not, WOULD NOT TRY, unless you know for sure. I have ran end mills in my router for 25+ years but they don't have the flat spot thingy either.
That would be an end mill,
Ray Thompson - Middletown,IN
>by that description. Held in a holder by a set screw or in a collet, and no they don't feel as sharp as a wood working tool. Used for cutting soft steel in a milling machine.
Ray
Mike Baker
>That is INDEED an "End Mill",,, 4 "flute"
A common cutter used by machinist to "mill" materials.
Toolmaker for 27 yrs regards:
Mike
