Lacquer
W.C.Settle
>What is the difference between automotive lacquer and lacquer used on wood?
Lacquer
W.C.Settle
Assuming solvent based
>Nitrocellulose based lacquer is never used in automotive formulations. Aside from that, clearcoats for either application are available in similar formulations, one part or catalyzed, based on different resins such as acrylic, alkyd, urethane, etc. Automotive lacquers can be used on wood with no problem. I have used one part acrylic auto lacquer on projects where I wanted a high gloss finish. It compounds super clear and glossy. After more than twenty years there has been no change. My current usual finish is Sherwin Williams alkyd lacquer in a medium rubbed effect with a final rubout with Butcher's wax and 0000 steel wool. It's a no-brainer finish, self-sealing and good on bare or stained wood as well as over pigmented interior or exterior latex/acrylic paint. Also good on metals.
Clint
