Keeping glasses/spectacles clean
Jason Roehl in Lafayette, IN
>I have done much spraying of various materials over the years, and I don't wear goggles or safety glasses, just my usual Coke bottles.
Anyways, after years of basically scratching the snot out of my glasses in a year or so, I finally asked about cleaning glasses at the optometrist as I was picking up a new pair. Some of what follows came from them, some of it I have figured out.
1. Use no wood-based products--no facial tissue, toilet paper or paper towels. These will scratch lenses, particularly polycarbonate or high-index plastic (what I wear due to my prescription).
2. Use a dedicated glass-cleaning agent. I get mine at Meijer's (mega grocery store) in a pump-spray bottle. Spray it on liberally and use your fingers to rub it around, then rinse it off and/or use a soft cloth to dry them. Terry cloth or cotton blends work fine.
3. If spraying a finish, clean early, clean often. "Young" finish is much easier to clean off than specks of finish that have been allowed to cure for even a day.
4. If you get some sort of dust on your lenses, rinse it off under running water before you clean your glasses, otherwise, it will just act as an abrasive.
5. In a pinch, I have found denatured alcohol or a strong ammonia solution excellent at cleaning my glasses as well, with no damage to the lenses. I even add it to my windshield washer fluid, as it lowers the freezing point of the summer formula, and I think it helps clean the windshield of my truck better (only takes a few ounces per gallon).
6. For the toughest specks on my specs, I will spray them down with the glass cleaner (seems to be an alcohol and some surfactants) without wiping them off before I take a shower, or I will put an ammonia solution in the sink and let them soak while I soak. After the shower, I clean them as described above.
Jason
