>I am using purple heart for a project and am uncertain about how to finish it and retain the great color and grain. I would appreciate any suggestions or experience you might have.
>Bob, you'll find out soon enough that you can't do anything to prevent purple heart from losing the purple color. I have a small tabletop I made using mahogany and purple heart many years ago. Since it wouldn't see tough conditions, I used a Danish oil followed by a coat of wax. The purple heart turned a real deep burgundy and looks fantastic along with the mahogany.
Just choose a finish that fits the conditions your project will endure but don't expect it to stay purple for long.
>David is right about the inevitable color change in purpleheart (and many other vividly colored woods). That said, there are a few things you can do to keep the color alive longer. One is to use a film finish with UV inhibitors in it. Various lacquers and varnishes are available in UV formulations. Another trick is to keep the wood out of direct sunlight and/or very bright places. Ultimately, most purple and blue colors are "fugitive" and will become brown or greenish. African padauk, which is bright red-orange when freshly cut, turns a muddy brown with exposure to light and oxygen. It's all a matter of time. That's why it's a good idea to design your projects with the final color in mind, so you don't lose details and contrasts that are dependent on the original color.
>a clear thin film finish that completely stops UV and the discoloration and deterioration it causes, I'll bet they could sell many thousands of quarts for $100 each. (I'd put my order in). It may happen - but I bet they find a cure for the common cold first.
>... but they can't always maintain a certain color. I like dyes on walnut and other species where the natural wood is likely to go to a yellowish cast over time. A rich reddish brown dye over a shock coat of yellow will yield a look that is authentic and lasting.
Purpleheart is a tougher cookie. You could put a grape-colored dye on it, but since it tends to darken and turn brown with age and exposure, the purple dye will lose the battle. Dyes are best for deepening and maintaining color that would ordinarily fade.
I don't mean to oversimplify this. The complexity of color consumes the conservator community all the time. We can only hope to think each situation through and come up with a specific solution in each case.
>I have a Purpleheart coffee table which I refinished with a magenta alcohol soluble aniline dye (Mosers) about 6 months ago. I used a waterbased top coat by Target (USL). This is my experimental piece to see how the dye works. So far it still looks purple. The table is in a room that gets a lot of sun in the morning. We will see how well it holds up.
I originally finished this table with just Enduro waterbased finish and it turned brown rather quickly with a bit of sun in a gallery window.
