Drying cookies
Drying cookies
Drying cookies
Lee Ohmart
>This weekend we had to take down two red pine that my father planted at our camp when he bought it in the 1960's. We cut some cookies from the stump. I plan to run them through my bandsaw and make finished slices that I will mount on slate bases for family members. I thought that they would get a kick out of labeling various rings with the dates that are significant to the family. The question is, how do I dry these so they don't crack or warp? Should I slice them up before or after they are dried. Would this be a good application of the PEG based penetrant that was discussed here?
Re: Drying cookies
Lee Grindinger
A very difficult thing to do
Lee Grindinger
>I remember reading a master's thesis on drying end cuts several years ago. It involved masking the outer rings from drying too quickly so the inside would shrink before the outer parts. Even under very controlled conditions the success rate was quite low.
PEG is a good option here. If you can get the slices thin enough to allow the PEG to penetrate deeply enough it will go a long ways in preventing the shrinkage that causes the checking.
Lee
Re: Drying cookies
Re: A very difficult thing to do
Lee Ohmart
>Thanks for the reply, Lee. I knew going into this that drying a cut of this type was going to be extremely difficult. The forums previous discussion regarding PEG preservatives was the only thing that gave me any hope of success. I better start looking for a supply................Lee
Re: Drying cookies
Rick L
Re: It's possible with Pentacryl *LINK*
Rick L
>http://www.preservation-solutions.com/index.php If you follow the instructions you can dry crossections without splitting. PEG is old
school and can take several years. Pentacryl doesn't have the waxy surface of PEG so you can actually glue or finish wood treated with it.
Pentacryl
Re: Drying cookies
Re: Drying cookies
Bos
>Lee. I have successfully dried freshcut cookies without cracking and without using sealants. Bag the cookie in black plastic and seal. Place the bag on sidewalk, deck or driveway in full sun. Early next morning, unseal bag, remove cookie, turn bag inside out, replace the cookie and reseal and leave in the sun. Moisture released the previous day will condense on the inside of bag during the night, and is removed from the process when the bag is turned inside out. Repeat this process until there is no longer any condensation inside the bag. The cookie is then dry to the current humidity equilibrium. I have dried cookies that are one inch thick and up to 24 inches in diameter without having splitting or warping issues. Give it a try. Only costs a few garbage bags. bos
Re: Drying cookies
Re: Drying cookies
JohnKJordan in East TN
>Another crazy idea is to go ahead and make a radial cut which may relieve enough stress to prevent cracks elsewhere, then incorporate the resulting wedge into the design somehow. I can also imagine a very nice table constructed with some contrasting wood strip down the center of a round cut entirely through the diameter.
Re: Drying cookies
Re: Drying cookies
>There was a discussion somewhere of taking two cookies and very carefully cutting a wedge out of one to fit the crack in the other and trying to make it invisible. You could probably make three out of four if you tried.
