Shaving Mule pics..
Shaving Mule pics..
Shaving Mule pics..
>I copied the mule from the ones that Country Workshop sells (they also sell plans). One of their guys has taught at John C. Campbell Folk School and has also built a number that grace the front porch of the Wood Working studio there. I made mine a little longer. I think for my next one, I'll build it all out of hardwood. I built fine out of fir. Here is a pic of the back legs - I cut the double compound angle with a dozuki saw because I wanted the portion that I cut off to be the spacer for the rear legs.
Re: Shaving Mule pics..
Re: Rear legs, side view...
>The legs are pine. The rest of it was fir.
Re: Front portion...
>I used zinc plated bolts. If they are available, I'd probably go for stainless.
Re: Post and "anvil"..
>The platform is two pieces of plywood - easily replaced. The post is the working part. I've broken teeth off of mine several times. This is the fourth post on this mule. The next one, I'll go ahead and change the angle on the chock which goes into the teeth of the post.
The chock is just held by a hardwood dowel. I used beeswax to lubricate the dowel (very liberal application). You need to wax the dowel every couple of years. I've got a bungee cord from the back to the bottom of the chock. This keeps constant pressure so the chock will engage the teeth of the post.
>Your anvil or table has too many teeth on the adjustment, no wonder they are breaking. My shaving henny has three adjustment holes and I only ever use one.
I don't know the throw of the head but it seems to me you could make it adjustable with three teeth, wider spaced, reducing the tooth breakage problem.
I must admit I have never seen that style of horse (mule) before.
Stephen
JohnKJordan in East TN
>JL,
Thanks. This gives me some good ideas.
How high did you make the seat? Is there an ideal height? I like the idea of a sliding seat.
Also, did you figure the angle of the dumbhead to custom fit or is there a "standard" angle?
I plan on making mine from white oak or perhaps black locust. (If I use the locust, it can stay out in the rain) I have plenty of both (and other species) if you want some for your next horse.
>I used 10 degrees. Though you could probably use a little more or less. I tried 15 degrees, but it was a bit high.
