Wacky screw question(s)
wilbur
>I stopped by the local borg (I know, I know) to get a few wood screws in a size I didn't have on hand. I noticed that my choices in regular zinc plated steel wood screws were limited to flat head phillips or round head slotted screws.
Why wouldn't they stock round head phillips wood screws? They have a lot of round head (pan head) phillips sheet metal and machine screws.
Second question that occurred to me as I was thinking about this: Why are screws associated with electrical boxes (light switch, outlet plates) always slotted screws?
Re: Wacky screw question(s)
I can't answer the first part of your question...
>however, I do believe the slotted screws discourage power screw drivers that can damage the parts if over tightened. I could be wrong but I think that is the reason.
I am happy with the slotted screws that are available, the only problem is that nasty zinc coating. However it is easily removed with a mild acid. I am doing a continuing experiment of removing the zinc coating by soaking the screws in urine. Seems to be working, rather slowly, but inexpensive and a renewable natural resource.
Stephen
Re: I can't answer the first part of your question
>Odd that you would mention over tightening screws. I was talking to my electrician buddy, wondering why the battery powered drill I have has the setting on it that limits the torque to No. 1 which is so weak you can stop it with your fingers. His answer was that was their favorite setting. You can put cover screws in all day long, fast, without fear of over tightening them.
On coverplate screws....
Jason Roehl in Mulberry, IN
>I actually ran across an electrician this summer who was so anal about his work that he went through the whole house and made sure that every coverplate screw's slot was vertical.
So, when one of his workers, whom we nicknamed, "Black Paw" couldn't keep his filthy hands off our freshly painted walls when he installed (and later re-installed) a wall sconce, causing us to have to touch up that area TWICE (trying to meet a deadline...), I couldn't help myself from randomly turning a screw here or there in just about every room as I was looking over the walls. He later noticed and fixed them all...
I don't bother with cordless drill clutches, I just hold the drill lightly and let my wrist flex when the screw is tight. Rarely do I over-torque a screw that way. I also use the 'high' gear setting for less torque and more speed.
Jason
Re: On cover plate screws....
>Jason, setting all the screws in the same position used to be considered good workmanship, at least locally, for electricians. One of our bigger builders demands it and as an added feature has them set the screw in the switched outlet horizontal. I can recognise their houses from this one thing.
PS, A friend just had a rental house painted, (I know you are a pro painter), You could have done a better job with your sock tied on the end of a crooked stick for a brush. Sheesh.
I've only ever heard of gunsmiths being that fussy
John in New Mexico
>Lining up the screw heads I mean. I think I remember dad telling me the stockmakers call that "blousing" the screws.
I always figured the slotted screw on electrical parts is due to some one inevitably painting over them. A slotted screw you can force the paint out of with the screwdriver and a couple firm taps - paint breaks loose and can be cleared out the side of the slot. Doesn't work so well with phillips or square, since they're closed all around.
I agree that round head screws are waning in popularity, they're still around but the borgs don't carry them, probably Ace and the like doesn't anymore either. Can't remember ever seeing one with a phillips head, maybe thats why.
Re: One Answer
>Is that most people who shop the Borg for screws don't know the difference between a sheet metal screw and one designed for wood. Therefore the efficient Borg carries only the sm type.
You want roundhead screws? Go to McFeely's.
mm
I would be concerned!
Lee Schierer - McKean, PA
>Since the threading of the screw hole is a random occurance where the threads start, I would be concerned that always turning the screw slot to be vertical or horizontal would either leave the screw loose or too tight in the majority of cases. #6-32 screws don't take a lot of torque to snap off and tightening the coverplates too much can result in the screw hole on duplex outlets cracking depending on what type of plastic they are made from.
just my 2 cents..
Lee
Another thought
Al Goldstein
>Possibly another reason you don't see round head phillips screws is the automobile manufacturers' assembly line. There workers repetitively use a power screwdriver to fasten screws. Flat head phillips screws are used to prevent the screwdriver bit from loosing its purchase and causing damage to the automobile interior. So slotted screws and round head phillips screws could cause a lot of random damage.
Just my $0.02
Al
Jason Roehl in Lafayette, IN
Re: I would be concerned!
>Lee,
Every receptacle and switch I've seen in recent years has some sort of threaded, metal hole for the coverplate screws, whether it's two to hold on a switch cover or the one between the two outlets on a duplex receptacle. The problem would be cracking the coverplate, but many folks these days use a flexible coverplate, so a 1/4-turn either way isn't a big deal at all. Personally, I prefer hard coverplates because you can leave the switch or receptacle slight loose in the box and use the coverplate to center it or otherwise align it, etc.
Jason
