Router table laminate question
Jeff H. - Oregon
>I am making my own router table and in the process of putting on the laminate. Should I cut out the hole for the router insert and install the t-track first??
Re: Router table laminate question
Ken Oakley-Sunny St. Cloud, Fla.
>When I made mine I put the laminate on first then cut hole for insert and the groove for the track. In fact I added the track about a year after making the table.
I made mine from plans in American Woodworker which is what Norm used when he made his.
Later added an Incra fence
Ron Hildreth, Alta, Iowa
>Jeff,
To answer in one word, No.
Reason is you will want your laminate to be at exactly the same heigth as your router plate and T-track. Lay down your laminate, then use your router to mill out for the base plate and track. Make sure you score the laminate first to prevent chipping and tear-out next to the grooves you cut.
Ron in Iowa
>Ken,
How do you like your Incra- fence on your router table? What don't you like, and why. What's your primary use?
Been thinking about up-grading from the Rockler fence I use now.
Thanks,
Ron in Iowa
>To be honest I bought it when Incra ws showing all the fancy dovetail cuts that could be made and being a real "Gotta Have It Gadget" guy I bought it. The video made it look like a piece of cake-Yeah Right!!! Learning curve higher than learning to fly a 747.
But it has seved me well as a standard fence. Easy to use,micro adjustment when you need to shave off just a smidgin, and easy on and off table when needed. Quality wise it is top notch, but 10 years ago I paid $280 for it and most of my routing on the table is done with patterns and cutters with follower bearings. Would I buy one now? Knowing what I know probably not. Still haven't made one box like they did in video.
>Thanks, Ken!
What is it they say- Fishing lures catch more fisherman than fish!
I'm somewhat the same as you, but I'm careful about buying snake oil!
Ron in Iowa
steve - Denver
>Ron, I have an Incra Intelli-Fence, I'd sell you for a good deal. It would be the fence only would not include the positioner. If interested, drop me an email and I'll send you a few pics.
a router table with no fence Router table
del schisler
>here is the best router table Of course you can make one But if you want to get one and get going on routering I have 5 routers and use some all the time I make jewelery box's and tables their are lot's of item's from this site Also the router work shop site also the best del
http://us.oak-park.com/catalogue.html?list=BYOT--
http://us.oak-park.com/catalogue.html?list=RT01--
http://www.routerforums.com/
