Mast-R-Slide
Mast-R-Slide
Mast-R-Slide
Doug Reynolds in Seattle
>Does anyone have any experience with the JessEm Mast-R-Slide? Looks pretty good until I can scrape up enough for a down payment on a Felder.
Re: Mast-R-Slide
Fine piece of equipment
Charles R. Smith from Victoria
>I have one on a General cabinet saw. It is a very well designed and beautifully made piece of equipment. It is sufficiently solid to handle some pretty heavy tasks with thick, rough-cut lumber. Though it takes a few minutes to get it set up, the process is well explained by the manual. But it is worth it -- riding on all those bearings (32 of them, if I recall correctly), it is very smooth.
I didn't remove my extension wing, but rather drilled and tapped it such that the Mast-R-Slide runs outboard of it. I was worried that it might be too far from the blade, but it is sufficiently solid and accurate that there have been no problems. It's a nice piece of equipment which makes me very feel safe when using it.
Charles (who likes his pimped-up table saw)
Re: Mast-R-Slide
Re: Mast-R-Slide
Kneale Brownson in sunny N. MI
>There's a thorough WoodCentral review HERE
Re: Mast-R-Slide
Re: Mast-R-Slide *LINK*
arw01
>Garrett did an excellent review article here on Woodcentral. Go check them out on the frame to the left.
Alan
Jess-Em review
Re: Mast-R-Slide
Re: Mast-R-Slide
McKay
>I have a slide on my unisaw. I had to take the wing to a machinist to have the edge machined flat. The wing's edge was not nearly flat enough. I did this because I did not want to lose the width of the saw table. Through the years, I have had many miter gauges, but this is the only one that I have really enjoyed and trusted.
Re: Mast-R-Slide
Re: Mast-R-Slide
steve - Denver
>Do you get emails from Rockler and do you have a store near by? They send out 20% off coupons every once in a while and that would help with the cost of this.
Re: Mast-R-Slide
Re: Mast-R-Slide
Ray Newman
>McKay: I also run a Unisaw. Did you add any form of additional support to/under the extension wing or the slider?
I've often wondered if the extension is strong enough to take on the additional weight & not sag over time??....
