>A front porch is constructed of 2x8 pine on 24-inch centers with a field rock foundation. The span is 8 feet and the porch length is 16 feet. The porch floor is 1 inch rough sawn pine. When the porch collapses, how many hound dogs will be killed?
>Since the number of dawgs is Directly Proportional to the number of monkeys on any given porch at the time of collapse, but the question didn't supply that figure, an accurate answer is not possible. It would also be helpful to know how many exits the given porch has since the number of casualties will be Inversely Proportional to that number.
>If'n wun end is south of The Line, it shorely means thet the porch is facing either East er West. Now you went and complicicated things cause you need ta figger in the season which effects the sun angle and therefore the 'mount of shade on the porch in question.
>Absoulty none. Hound dogs are to smart to stay under the porch while it is collapsing. There noses are so good that they can actually smell when the termites are about to eat all of the way through the supports.
