the art of resawing...
Edward McCormack
>Was just given a 10" Craftsman bandsaw from my brother, Im wondering what i have to do to resaw some wood to make vaneers. I clamped a staight edge to the tbl but the cut keeps wandering it drifts so the begining of the cut is at the right size but as i proceed it thickens. The blade is in the rollers and stays in the rollers. Any1 that can give me advise, Thank You
Re: the art of resawing...
Re: Here are the basics
Grant in Iowa
>First off, you should be able to find some tips on the internet by searching on Bandsaw resawing, but I will provide you with the basics to get you going:
-Your saw is a bit on the small side for resawing, but it should work so long as it is well tuned and has a sharp blade. Also consider searching on "bandsaw tuneup".
-Take a piece of scrap and scribe a line parallel to the edge along its length. Then, without using the fence, follow that line for a while until the blade is following the line well. You will be swinging the end nearest you left and right slightly until you find the balance point where the blade follows the line. As soon as you find the sweet spot, stop feeding the wood and while holding it at that spot turn off the saw. Now make a pencil line on the table along the edge of the board. This angle is what is known as the "blade lead" of the saw with that blade and at those settings. This is also the angle at which you should set your fence. This angle may not match a line perpendicular to the front edge of the table...this is normal. Note that this angle will also change depending on the blade used and other saw settings, so each time you resaw you want to do this test. Set up your fence parallel to that line and the saw should cut straight at that point. If not, or if the balde wanders back and forth then you need to align the saw or get a new blade.
Hope that helps,
Grant in Iowa
Another basic
Lee Schierer - McKean, PA
>You will need to tune your saw (align all teh wheels and guides to each other) and use the widest blade a 10" saw can handle tensioned to the maximum.
Most of the time you won't find a single sweet spot that will work for the entire length of wood, so a curved fence guide also known as a resaw guide should be used and you will need to continually adjust the trailing end of the board left and right as you saw through the length while keeping the face against the resaw guide..
Lee
Pat Evans
>In the October '06 issue of Wood magazine, there is an article on how Michael Fortune tunes his band saws. Supposedly, drift should not occur with a properly tuned band saw with the correct blade and with the correct feeding techniques. I haven't done resawing other than a few test samples on my new 18" Jet, but there was no drift on the samples.
Edward McCOrmack
>THank you ill try it tommorrow.
JKJ in East TN
>What I found useful in resawing:
Coplanar alignment of the wheels of the bandsaw.
Careful adjustment of the guides.
Proper blade tension.
Very sharp quality blade.
Tall fence.
Careful drift compensation.
Lots of patience.
I've cut some relative short boards, but once a friend wanted me to resaw a long douglas fir 2x12 into four boards. I had just adjusted and tuned the bandsaw (14" Delta with riser block). It took a while but worked fine. The boards needed just a little planing.
Stress the sharp blade component.
Don Henthorn
>All the other things may be right on but a dull blade is going to wander.
"RJ" Whelan
>The bandsaw is probably the most used stationary power tool in my shop: I do lots of bookmatched panels and elements, but very little veneering. I have owned everything from a 3-wheel Inca to a 30� Oliver and even an Hitachi Resaw. I currently use a 14� Delta with riser.
I have found the following to be the most important components to successful resawing:
1. A sharp bi-metal blade � �� is my normal workhouse blade.
2. No more than 3 TPI � any more than this and the gullets can�t clear the waste quickly enough to avoid overheating. For wide boards (over 8�) I use a 2 TPI blade.
3. Reasonable blade tension � I use a tension gage, but the built-in scale is, usually fairly accurate. Very high tension can bend the saw frame and will definitely shorten the life of the blade. Low tension can actually cause the blade to drift within the board (accurate top and bottom and off in the center of the board.
4. Forget about co-planer wheels. Back the guides off and adjust the top wheel so the blade rided dead center on the tire (make sure the tires are in good shape or the blade won�t track no matter what you do).
5. Adjust the side guides to that they are very close to the tensioned blade � I use a dollar bill for this. I adjust the guides so that they ride just at the back of the gullet.
6. Adjust the rear bearing so that they are not touching the blade during free spinning � a dollar bill folded in half is close.
7. Whilst resawing you will sometime release tension in the board being sawn; this can cause the board to push on the fence and cause the blade to �appear to wander�. I use a relatively short (in length) fence (12� � 7� in front of the blade and 5� behind).
8. A feather board to hold the board being sawn against the fence � this allows you to use both hands to feed the board instead of trying to maintain pressure against the fence with your right hand whilst feed with the left. The feather board bears against the approximate center of the board � so for an 8� board try to have the feather board apply pressure about 4� above the table.
Good luck with your resawing � once you get the hang of it, you�re going to love the graphic possibilities offered by grain matching.
RJ
Hi Skip
