OT- Ink jet cartridges
Dave in Haverford, PA
>Does anybody know of a source for these at a discount? My printer cost $120 - just bought a set of cartridges at Staples for $75!
Re: OT- Ink jet cartridges
Tom
>It depends on your printer. Most, if not all, cartridges are chipped these days. If yours isn't, I buy from abcink.com and 123inkjets.com (both email 25 to 30% off coupons very frequently). Megatoner is another reputable site. I usually pay $1.50 to $2.00 per cartridge. If you can find an older Canon, it's worth buying, just for that reason. Even if you need to spend $50 on a new printhead. What do you have?
Lee Schierer - McKean, PA
>You just found my #1 reason for switching to a laser printer. EWven thought the cartridges cost a bit more, they make 10-50 times more copies for the price and they don't dry out in the meantime.
Lee
Alan in Little Washington (NC)
>I think Walgreen's (or CVS?) has a relatively inexpensive refill service now. Check it out.
Mike F
>I've used http://store.simplyinks.com/ before. Their ink prices are basically free. Before I tossed by Epson printer out, I bought some of their ink. It worked. Their ink cartridges cost around a buck each. Much cheaper than the $18 each that Epson wanted.
Dave Herman. West Chester, PA
>My daughter's printer she uses for college needed ink at $57.00 for the cartridges, so I went out and bought her a Canon pixma for $45.00. It's crazy when the printer costs less than the price to buy new cartridges.
I've had good service and low cost from www.refill
Don Henthorn
>from www.refills.com
Larry Clinton
>HP, Cannon and some of the others use a print head built into the cartridge. These are patent protected so generic cartridges are not available. Epson has a separate print head - cartridges just hold the ink although they install a chip that tells the level and tries to prevent use of Generic cartridges. As I have read, most, if not all of the printer companies sell the printer at or below cost - making bundles on replacement cartridges. I use an Epson - with generic cartridges. Only one time the chips wouldn't read properly, the company replaced them without a problem.
My advice: First check EBAY and search the web for replacement cartridges at low cost, note the models of printers that they fit, then buy one of those printers. My current printer is an Epson Stylus R200. I purchased the cartridges I am using for $2 to $4 apiece on the bay. It uses 6 cartridges for a set - bought 6 sets + some extra black for around $75. Been using them for about a year and half now, still have plenty left. I may lose some due to ink dry-out - haven't yet. The printer works like a charm, have to use it about once a week or have to run the cleaning routine a few times. I always try to print something in color every few days - saves the cleaning and prevents clogging. I have lost 1 printer due to clogged print head a few years ago. Still I print a ream of paper or three a year with very low cost. My printer does a great job on Photos too, I purchase a good grade of 8 1/2 X 11 matt paper in boxes of 200 sheets (agfa brand) fairly cheap & the photos rival the CVS prints.
Bill Kay
>Hi All,
An aquaintance of mine got tired of being ripped off every time he needed to get a new ink cartridge. Now he watches for "loss leader" printer sales and buys two. One is placed in service and the other goes on the shelf. As soon as the printer runs out of ink he either uses the cartridges from the new one or just installs the new printer. The used printers are donated or given away.
There is a Big Box store out this way called Fry's. http://www.frys.com/ Quite often the in store prices, on selected items, are lower then the on-line prices.
Here is an HP Deskjet D2430 Printer for 40 bucks.
http://shop2.outpost.com/%7BXHoRnvtn8ZSB+7SG--BF9Q**.node1%7D/product/5248517
Re: New machines often have "trial"
Larry Clinton
>cartridges. You have to read the fine print describing the product. These don't have the capacity of the regular cartridges. Therefore buying a new printer to get the cartridges is often not as economical as it seems.
>Thanks to all! I'm going shopping-
I guess those are special
Don Henthorn
>I buy cartridges for my Canon S750 from refill.com for less than $3.00 regularly. They have worked well for me.
Re: New machines often have "trial" *LINK*
bill kay
>Caveat Emptor
Everybody needs to pay attention to the "fine print" these days which is the underlying cause for this discussion. If the printer manufacturers were upfront about the true cost we wouldn't have to attempt re-inking. The current manufacturers efforts of chipping and date coding to stop us from re-inking will eventually backfire.
Caveat Emptor
JKJ in East TN
I hope so, but that's what many said when Epson started chipping their printers years ago and the practice has only expanded.
I read once that printer mfgs make very little money on printers and expect to make most of the profit on ink, on the fringe of the loss-leader concept. They consider the "evil" consumer practice of reinking as cheating them out of the rightful return on their investments. I would prefer paying more for a well-made printer and less for the consumables.
Costco + Printer cost
>They have ink for some printers. If they have them for your printer, they are the most reasonable around - though you buy packs of ink.
Someone mentioned they would rather pay more for the printer and less for consumables. The ink actually costs much less for the more expensive printers (often/usually). They use much bigger cartridges and use single color ones so the cost per page is much less and you only need to replace the color you run out of (usually black). I priced them out a while back and bought a $275 printer instead of a $60 one for my wife and daughter.
For normal black printing, I use a laser for the reason mentioned above.
Re: Sorry Don, Some cannon do have the
Larry Clinton
>printer head built into the cartridge. All HP and Lexmark do, I did some searching and found that some cannon are built like the Epson's with a separate print head. I tried to find generic cartridges for one some time ago that was a print head cartridge. I was unaware they built both. I have had several Epsons - none of them have the print head in the cartridge. Per my message my last cartridges cost was less than $2.00 each for generic Epson.
