Yes
>Barry,
Since solvent finishes have 100% burn-in (dissolve and then re-fuse with prior layer), the thickness of the film "builds" with subseequent applications into a single layer. There is also a minimal amount of penetration into the wood fiber. Depending on the wood and how the finish is rubbed out, there will be a wide variance in the results achieved. The thickness of the film will effect how light is reflected and refracted inside the film layer adding or subtracting from what we call "depth" as opposed to "closeness" to the wood. For instance, some don't like oil poly finishes because the initial film is thick and can look "plasticy." Oil finishes (and most waterbornes) do not burn-in with prior layers. When they are cut back and rubbed out, care must be taken not to work through the top layer to avoid witness lines between the coats being exposed. This doesn't happen with shellac and lacquer because the finish has become a single layer.
Shellac, while durable, is easily attacked by alcohol and ammoniated compounds, and its resins are not as hard as those in lacquer. Both films need some thickness for durability on wear surfaces. Their great allure is that either surface can be repaired simply by recoating with the original finish. Also, too thin a film will allow water (spills & vapor) to penetrate under and weaken the film bond with the wood.
Lastly, shellac can be tinted with compatible dyes and used to shade various parts of a piece to even out the color of the wood. This is especially useful when working cherry. Obviously, the more that is applied, the more tint will result. 100% dewaxed shellac will produce a harder, less flexible film than regular shellac. Instrument makers actually add wax to their shellac finish to allow the film ro expand and contract with the wood's seasonal changes without cracking. It is, however, softer and less durable.
Note of caution. Many use shellac as a barrier coat under waterborne finishes to seal in stain and prevent grain-raise by topcoats. Issues have come up with shellac basecoats cracking and crazing under the waterbornes. If you'll be topcoating with a different finish, keep your shellac coat thin, make sure it's wax-free, and use only fresh product, preferably mixed from flakes as the undersealer.
mm
