THE WOODRAT IS BACK!
Workshop air Conditioner
Rick Snyder
>Hello,
I currently have a (1) car garage workshop. I have a window on the back wall. What would be the pros and cons of a unit like that?
This summer has been a hot one and have not been in the shop much.
Would think about putting in one next year.
Thanks,
Rick
Re: Workshop air Conditioner
Sean Troy
>Should work just fine. You wouldn't need a very big one.
>I use a window unit to cool 500sf. It works out well for me except on the hottest of days. But even then it cools to a tolerable temp. Of course insulation is a big help too so if you haven't already, think about insulating.
Tom
Grant in Iowa
>Rick,
I cool my new 33'x44' well insulated shop with a small 5000 BTU window unit that I mounted in a dedicated hole in the wall. The unit does a good job in large part because I leave it run at a moderate temperature all summer...night and day. I have done the math on its power draw and it might cost me $10-$15 per month at most to run it like that...a price I am willing to pay for a cool humidity free shop.
Given its small size, on the hottest days here in Iowa, the unit keeps my shop at no more than 82-85 degrees...fine for my needs. Note that the average calculations are based on keeping your space at 70 degrees...so the manufacturers recommended sizes are therefore much larger.
One small issue I have had is that the unit runs constantly on the hottest afternoons. This means that it can frost up during this time...but keeping the thermostat at a reasonable setting prevents this....it happened to me only once. in this very hot Iowa summer.
I have about 3000 BFt of lumber in the space in storage so it is important to me to keep the air at house humidities for lumber moisture reasons as well.
This time of year you can buy these small units for under $100.
FWIW,
Grant in Iowa
Re: Plant a tree
Al Stokka - Cambridge, Iowa
>Rick,
I have a double garage approximately 26' x 28'. The interior is drywalled and about one-half of the north wall abuts the house. The walls contain no insulation. The ceiling has 6" kraft-faced fiberglass. I ran a 5000 BTU window unit this past summer at 75� and was surprised at how little it ran. A 75� workspace is great!
Oh, one more thing (and the reason for my subject line): I think a great help at keeping the garage cool is the huge soft maple tree which shade 80% on the garage roof except in the early morning.
My advice? Get and install the window air conditioner but, plant a tree (or three or four) too.
Al
>I agree with the others. I have a 0ne car garage work shop attached to my house. Its on the lower level but not really a basement. I have one long wall facing north and the overhead door faces east. The other two walls are "interior" walls and all are insulated. I am in humid southside Virginia. I have a 5000 BTU window unit and it does a good job. I just turn it on when I walk in and let it run. Probably won't cool the shop to 70 in the hot part of the day, but the dehumidification and cooling are really worth it, and change the entire feel of the shop. Makes it very tolerable. I have had it for three years. Might be the best $89 I spent on the shop. If I were you I would be shopping the Borgs and Walmart for units right now. Catch and end of the year special. You might get a bigger iunit cheaper. I might have bought a bigger one, but a one ton one was seriously more money. They jumped to about $225 to 300. Sort of took the fun out of it. Go get one. Tell anyone that asks I said it was OK.
Ron Hildreth, Alta, Iowa
>Too bad I didn't think about you guys out in the hot garages this past year. We installed central air in our house when the old furnace was on it's last leg, and I would have given, for the taking, an 18000BTU window unit that was only about two years old. My shop is still in the basement- naturally cool down there!
One quik question--- How many times a month do you guys need to blow the dust out of your window units?
Ron in Iowa
>I blow mine out about once a week, If its lucky. Try to remember, but not a big priority. I may be here wailing and gnashing teeth over forgetting. I do have a DC and a Home made Air cleaner.
Jim in Burlington Ont.
I have a new one
>Bought 3 12000 btu units at Costco this year. Never had a shortage of cold air and the electricty bill was super low. Those thermostat's are perfect.
Pete in Holland, MI
>If the AC unit will be a permanent addition to the shop, cut a proper hole in the wall and mount it there for a couple reasons:
1) Cold air falls. Mounting the AC unit higher on the wall will allow it to do a better job in the room.
2) Plugging up your window space with this unit reduces that much natural light space.
3) Leaving the AC unit in your window makes an eaiser egress for a burgler.
4) Window AC units look tacky (in my eyes) and should be removed in the off-seasons for appearance sake.
My 3 cents (adjusted for inflation)
insulate first, then heat pump *LINK*
Tom Sontag - St. Louis
>You will be asking a similar question about heaters in just a few months. I insulated my detached 2 bay shop and it has always been ~10 degrees better than outside - cooler in summer and warmer in winter. But on the hottest humid days and coldest ones too, that was not enough, especially for gluing in the winter. I had a radiant heater, but that was only good for warming hands and keeping my brain from frostbite.
I ended up installing this and so far, so good:
Amcor portable AC/heater
