Overhead Electric Heater
Howard
>Can you guide me to a source for this - I need a unit that will be installed into the wall for heat with a blower and runs on either 110 or 220 volts. I need to heat a small space around 10 x 12. Thanks for the help.
Howard
Re: Overhead Electric Heater
Charlie Self
>Try Northern. They seem to have more heaters than anyone else. Also, Lee Valley has a good hanging model you might like.
Dave Bair, Eaton Rapids, MI
>I'll second the Lee Valley quartz heater. No fan needed; all your electricity goes into heat production. On the high setting, it'll keep my 20'x20' shop up to 50� above the outside temp.
Re: W. W. Grainger
Al Stokka - Cambridge, Iowa
Howard
>Thanks All, I will check both locations.
Re: Overhead Electric Heater *LINK*
Kevin G
>I purchased and installed the unit I linked to when I built my shop a year or so ago. This thing, running at about the 50% setting on the built in thermostat, will run me out of the 24 x 20 shop, no matter how cold it is outside. I always keep the heat on, to prevent the temp from falling below freezing in the winter. (I have a very well insulated shop, so that helps.) We don't really notice much difference in our power bill either. I notice they also have a 120V unit now, which they didn't offer a year or so ago. Good little heater, I would buy it again in a second.
Farenheat shop heater
Stuart Johnson
>The specs list it at 7,500 watts. Does this mean when it is on it is running at 7,500 watts? If so, it sounds like it would be pretty expensive to run. For example we pay 14.5 cents for 1KWH in this case that means 7.5 KWH or $1.0875 an hour. It might not be so bad if it runs for a few minutes and then cycles off.
Every winter I start thinking about using something other than propane radiant heat which does work well but takes up floor space.
Howard
>kevin,
Thanks I'll check the link - do you spray finish? I do a lot and I am wondering what you do to keep a warm heater away from the fumes. Thanks
