OT Refrigerator Temp Question?
>After having several half gallons of milk go bad prematurely and complaining to the local grocery store, it finally dawned on me to check the temperature in my fridge. (Duh!)
My freezer is at about 10 degrees (F) and the refrigerator is about 40. I turn it down a bit and its now at about 35.
What is the best temp? I think it would be just above freezing, but I don't know.
Re: OT Refrigerator Temp Question?
>You probably have "hot spots" and "cold spots" in your refrigerator.
The "ideal" temperature is between 35-38 degrees for me.
I've got a couple of small dial type refrigerator thermometers that I use to monitor mine.
steve - Denver
>Our fridge recommends 37 for the fridge and 0 for the freezer.
Don't freeze the lettuce
Lee Schierer - McKean, PA
>You want it just cold enough that you don't freeze the lettuce in the vegatable bins and so the thanksgiving turkey will thaw within four days after you move it from the freezer to the fridge. There is nothing worse than a partially frozen turkey on thanksgiving morning with 20+ guests on their way. DAMHIKT!!
Lee
F or C ?
Neal in San Jose
>If your readings are in Centigrade, you have a problem!
Al Stokka - Cambridge, Iowa
>Barry,
Do you store the milk in the door rack? STOP THAT! The door remains warmer than the rest of the cabinet.
Also, the "sell by" date applies to unopened containers. Betcha didn't know that, didja?
Also (again), a thermometer placed in a glass of water (or other liquid) will give a more accurate indication of the average temperature in a refrigerator. You likely be surprised at the temperature fluctuation observed with a recording thermometer.
Al
Wise men who wear hats.......
>WoodCentral hats that is. I come here for sage advice from wise men with WoodCentral hats.
Yes, I keep it on the door. It rides out to meet me. I am too lazy to reach into the fridge. Guess I'll just have to work up the energy.
I knew the sell by date was for unopened containers. Even I am not stupid enough to buy an open container of milk. I did buy some open Tylenol once and that was enough to teach me a lesson.
Thanks for the idea about the glass of water.
I have been checking the thermometer at random intervals (Random because I don't want it to know the schedule and be able to get ready) It's all over the place.
Re: Semi-wise goofs from Iowa...
>"I knew the sell by date was for unopened containers. Even I am not stupid enough to buy an open container of milk."
Barry,
No way was I inferring that you are stupid (your posts can speak for themselves...He he he). I only meant that once opened, evil critters can invade your milk and do nasty things in there, causing accelerated, uhm, shall we say "aging" whereas if the container remains sealed and cold, the few critters remaining after pasturization do little harm? If you using unpasturized milk, which is great stuff, all bets are off.
Al
>Al, I grew up on a dairy farm and we drank our own milk. It was unpasteurized. Before I was born my father suffered some sort of disease you get from raw milk (brucelosis (sp?) or undulant fever), but apparently we did not learn the lessen and kept on drinking it.
As far as open milk goes, It occurred to me that the less milk you have left in the container the more quickly it goes bad. I am guessing it is a combination of more oxygen and more bacteria in the larger volume of air and of course more time.
Since I "lost" two containers of milk in a couple of months I thouhgt it was time to check the temp in the fridge. Got the thermometer in a glass of water and it seems to have settled at about 35 or 36 degrees. Seems good to me.
Pete in Holland, MI
>Is your fridge packed with stuff? My wife has a tendancy to do that and experiences the same problem once in a while. Newer fridges with the circulating fans need room for the air to blow around.
Heck, I used to leave the milk out for a few days
Don Henthorn
>and thought I was making cultured buttermilk. I drank a lot of that after I couldn't find real butter milk anymore.
I thought milk never went bad
r payne
>first it is milk, then curds and whey, then cottage cheese (after removing the whey), then some form of soft cheese and finally some form of hard cheese. Of course I've been known to drink milk I've had to chew.
ron
