Finshing live edge piece with bark on it
Mitch from TN
>I'm making a Nakashima-inspired piece that has a section of bark along one cherry board. I'm going to finish the board with oil, but I'm wondering whether I should put the oil on the bark or leave it alone. Does anyone have any experience with this?
Thanks!
Mitch
Re: Finshing live edge piece with bark on it
>I've turned natural-edge pieces and it's always a fight to keep the bark on during the drying (and warping) of the piece. Much depends on when the tree was harvested.
If your stock's dry and set, you can try soaking the bark layer with very thin CA (cyanoacrylate - super glue) to penetrate and reinforce both the bark and it's bond to the sapwood layer.
Hope this helps
>Finish it the same as the rest of the piece. If the bark is tight, no problema. If it's just a bit gappy, yellow glue and clamp it back first. Otherwise, strip it off and burnish the edge with a rotary brush.
Clint
