Have a question? Ask Woody!
uneven floor
uneven floor
uneven floor
Montana Mike
>I took out a section of wall to give an existing room a few more square feet. Well this is where my problem started. The elevation of the two floors, which are concrete, is about an inch different. I would like to put laminet flooring down. My question: Can I float the lower floor out to make it level enough to install laminet? This just involves about a four foot section where the wall was. I hope the answers are positive so I don't have to transition the floor at that point. That will be ugly.
Thank you, Montana Mike
Re: uneven floor
1" is a lot...
Hoa Dinh in Alameda
>when it comes to laminate flooring.
I think the requirement is 1/8" over 4'. If this is the case, you'll have to feather the difference out to 32'.
You need plan B.
-- Hoa
Re: uneven floor
Re: uneven floor
Kneale Brownson in sunny N. MI
>Which is lower, the section where the wall was or the rest of the room you want to refloor?
Re: uneven floor
Re: uneven floor
Thad
>use a vapor barrier (felt), fasten plywood to slab over vapor barrier(whatever thickness you needed to end with new floor level with existing floor), then install new floor. A 4' section shouldn't have any joints to worry about, but you would run the flooring perpendicular to the plywood joints.
Re: uneven floor
Re: uneven floor
Ron Hildreth, Alta, Iowa
>Mike,
I once saw where a guy laid down "sleepers" which were nothing more than furring strips, then tongue & grove sheathing to bring the floor up even . Over this he laid laminate flooring. It looked petty good, but not sure how long it would have lasted, as about six months later a neighborhood kid playing with matches set the house on fire and it burnt to the ground.
Ron in Iowa
Re: uneven floor
Re: uneven floor *LINK*
Thad
>this is not an uncommon method either, but has hystorically been done mostly w/ 2x4's on their side fastened to the slab. You stated the difference was approx 1", and I'd be skeptical of any sleeper strips under 1" thick.
Here's a link w/ a bit of information.
~ Thad
http://www.hardwoodinstaller.com/hardwoodinstaller/hardwoodonconcrete.htm
Re: uneven floor
Sure you can
Toney Robertson
>Is this your situation - You took our a wall and the concrete under the wall was 1" lower? The two floors on either side of the wall was level?
You can do one of two things.
1. Get you some floor leveler. It is a powder that you mix up. If mixed correctly it will flow to level so basically no troweling involved after putting the compound into the gap.
2. Get some latex concrete patch. Mixed it up and trowel into the gap. It can be feathered out very nicely and is very strong even when it is feathered out.
Either solution should work if I understand your situation.
Re: uneven floor
Re: uneven floor
Montana Mike
>Kneale, The wall I took out is a weight bearing wall, which I re-enforced with a 4x6 header where I removed the supporting pole. The largest area of floor (the lower side) is 15 x 15 and is level according to my 4 foot level and using the water test of pouring small puddles at various places on the floor. The water did not run in any specific direction. The same on the higher side. What I want to know is: can I pour a filler like thin set or something similar and run it out severel feet to acheive a fairly level floor?
Re: uneven floor
Re: Sure you can
Montana Mike
>Toney, The wall I took out is a weight bearing wall, which I re-enforced with a 4x6 header where I removed the supporting pole. The largest area of floor (the lower side) is 15 x 15 and is level according to my 4 foot level and using the water test of pouring small puddles at various places on the floor. The water did not run in any specific direction. The same on the higher side. What I want to know is: can I pour a filler like thin set or Ardex and run it out severel feet to acheive a fairly level floor?
Mike
Re: uneven floor
Re: Sure you can
Toney Robertson
>First, you said that it was a load bearing wall that you removed and replaced with a 4x6 beam.
How long was the wall? I am guessing 15 feet.
4x6 wood beam?
If I am right on the first question and the answer to the second question is yes then the beam is not adequate for the span and it will sag over time. There are many factors that come into play when removing a load bearing wall and sizing the beam that will replace it. Roof structure - floor span - point loads - a structural engineer would be a great place to consult.
As far as the floor goes, the best solution would be to fill the one floor an inch so that all is level but that would take a lot of vinyl concrete or floor leveler. Most people can detect small differences in the level of a floor. As someone else said 1 inch is a lot to take up over even 15 feet let alone 6 or 7 feet.
But the bottom line is it is your house and if that type of slope does not bother you then go for it. The only other consideration is the type of floor you will put on it. If it is carpet then no problem with the slope. If it is hardwood then that becomes a problem and you would have to consult the store where you are buying it.
Check out the beam. You don't want your floor above to sag.
