Finish for outdoor door
Link Van Cleave
>I have to refinish a door I built a few years back. It was finished with a poly. Thinned and wiped on, only a couple of coats as far as I know. Not built up on the surface. Trouble is the sun. The door is mainly mahogany, with a doug fir panel and madrone burl square thingies inlayed into the D.F. The sun has really washed it out. The madrone is really bleached out. I am going to try to sand out the oxidized wood and then, what to put on it.
General finishes has a outdoor oil with U.V. inhibitors. I was thinking of that or a ureathane spar varnish. I don't want a heavy finish that is hard to renew. The door has mullions and recesses which would make it hard to strip a film finish off there for I am leaning to the G.F. oil. Any ideas or experience with products you like.
Thanks,
Link
Re: Finish for outdoor door
Steve Schoene
>Spar urethane isn't generally a good idea. Consumer grade single part urethane, even if flexible enough to be a spar varnish, isn't very UV resistant and needs the UV protection additives to get up to just OK. There are some marine grade two-part urethane clears that apparently hold up well.
Oils of all sorts also don't provide much protection, because they can't interpose much UV absorption between the sun and the wood. If you are willing to remew FREQUENTLY--in some exposures and latitudes this could mean monthly--you can keep the wood from turning grey.
The boating community still believes that the best solution is high quality marine grade traditional spar varnish, applied in multiple coats (6 or more) and maintained regularly. (Actually, most of the sailors I drink with believe grey is the best color for teak.) There are three well thought of brands--Epifanes Gloss, Interlux Schooner, and Pettit Captain's.
In full southern exposure sun, regularly means annually in middle latitudes. So once a year, the door would be scuff sanded and a fresh coat applied. Dings should be repaired promptly. If you are hard on doors, a brass kick plate bedded on the lower rail might be in order.
In short, the best finish for an exterior door is a high quality exterior enamel, preferably in a light color. A porch roof to provide shade would also be a good thing.
Re: Sikkens Cetol or marine finishes
Dave Mount
>I have Sikkens Cetol on my house and trim and I'm very impressed with its durability. As already pointed out, a film finish is superior for protecting wood because there's more between the sun and the wood. On the house I have to recoat every 2-3 years on the SE face of the house that takes brutal sun, but it went 9 years on the NE side that takes very little. The down side of (most of) the Cetol colors is just that, that they impart some color. They do make a clear/colorless, but my supplier says he's not impressed with the protectiveness of the clear compared to the others.
Of course the other group of people that know about keeping outdoor wood bright is the boating crowd. Go to a marine supplier and ask for their highest quality clear finish. This is an app where every dollar invested in the material is worth it, because the labor in maintenance is huge if you don't buy the best.
My $0.02,
Dave
Jesper, Denmark
I agree with Seve, almost.....
Jesper, Denmark
>except that the annual refinishing is with several thin coats.
Cetol is also good, but on boatwoods, I find that it adds a dull color that looks unnatural.
Hey Link, you're back...!
HC Sakman
>I hope it's all well with you.
I'd use nothing other than Sikkens or Penofin.
They both comes in some different shades but if you're after some more color, Sikkens offer more choices.
Chico...
Nothing lasts forever
>DAMHIKT
Clear exterior finishes that preserve wood color forever are non-existent and I will be the happiest camper if proven wrong. Different varnishes, epoxies and UV coatings only delay the inevitable. You just need to decide how badly you want that natural wood look. And, depending on the finish, how committed you are to maintaining that look.
The debate about marine finishes, spar varnishes and other exterior finishes is missing the big point that nothing last long outside. If it did, I would have adopted it in my driveway gate business in the 80s and 90s. Anything you doto preserve wood color outdoors is a finely-calibrated equilibrium between the ravages of UV and the masking properties of your finish. Nothing I've ever encountered lasts more than a year without needing recoating or worse. I am not the final authority on this, but I bring a lot of practical experience to the table.
The "worse" is that, if you put a fancy polymerized, catalyzed finish on your wood, the wood color will bleach eventually anyway, and you will end up having to sand all that original finish away -- and more-- to get back to the original wood color. Some of those sophisticated finishes are really difficult to sand back or rejuvenate easily.
I hate to beat the drum for an old remedy, but I still subscribe to the notion of applying three coats of spar varnish at the outset and a coat per year forever. I have not found any UV blocking products that actually work for long. If any manufacturers would like to differ with that, please send me samples and test results.
This is an issue that won't go away. Thanks for raising it again.
Re: Nothing lasts forever
Steve Schoene
>I agree, but three coats are NOT enough for the initial applications if you have full sun. The makers of the spar varnishes all call for at least 5 (in one case) and mostly 6 or more. Lore around the boat yard calls for 6 up here in Connecticut, but in Florida, best start with 8 and the scuff and recoat interval becomes twice a year.
I also want to repeat myself that there are three good brands--Epifanes Gloss, Interlux Schooner, and Pettit Captain's. If you can buy it at one of the borg, don't bother--it may cost less than half as much per quart, but considerably more per year of service.
I have used Cetol. It can, because of the pigment, get away with a couple of fewer coats initially, but still requires a annual maintenance coat and after a couple of years really looks like paint. Also when it does deteriorate it doesn't do so very gracefully, turning a nasty dark color, and only lifting partially so that stripping to start over becomes a much harder task than with spar varnish which after 6-7 years can be removed a bit more easily. (I didn't say easily, just more easily.)
Those of us who keep bright teaks on our boats are certifiable but....
Jim Dillon
>Link,
The basic problem is that you cannot add enough UV inhibitors to a finish to keep it long-term weather (UV) resistant AND clear at the same time. So you are stuck with picking a premium boating finish as Steve suggested, and still redoing it every few years (that is what boaters love to do with their "spare" time 8-)) or leaving it unfinished to weather to a uniform gray and be done with it. Frankly, given the work effort needed for redoing a film finish - at least on outdoor furniture, I am really leaning in the direction of letting nature take its course on unfinished wood. As an aside, I've also had good luck with a stained Sikkens, but have no experience with a Sikkens clear finish. My 2 cents.
Jim
