Cutting large bevels (greater than 45 degrees)?
>I've got a project for some "portable" shelves which fit in a closet underneath some stairs. The wall angle is about 56 degrees.
Any good way to cut a 56 degree bevel other than by hand?
TIA.
Re: Cutting large bevels (greater than 45 degrees)?
I presume you mean cutting them with
Forrest Addy
>I presume you mean cutting them with a table saw RAS or whatever. Sure. Swing the saw to 45 degrees and block up your sled to support your work at the differential angle. If you don't want to cut an angle into your sled platform, block up the s;ed to the whole angle and clamp the work to it. It seems kinda tall and awkward but the sled makes set-ups like this manageable.
Use a jointer
Lee Schierer - McKean, PA
>You can cut this angle on the edge with a jointer. I would cut part of the material away with a 45 degree rip cut to save on passes across a jointer.
Lee
Lee Gordon
Lee Gordon
>Can you cut them at 34 degrees from the opposite side?
Jim Dillon
>JL,
Will the jig in Yeung Chan's book for cutting shallow angles on a TS help you? I built it and it works fine. I can post a pic, but I think you recently referenced Mr. Chans book in a post to A.W., so I assume you have it (I agree, it is a superb book). It mught help you out.
Jim
