OT..Need advice on installing 2x4 stud wall
Dick Haley
>My daughter moved into a home in Nashville, TN (East)and wants me to install a closet on an 8'(approx) wall. Would it be acceptable to anchor top plate of 2x4 stud wall using toggle bolts and construction adhesive to ceiling. Not sure yet if the ceiling is drywall or plaster. No access to attic to add nailers to ceiling joists. Same situation with anchoring to walls. Could get lucky and find wood but dimensions of closet (depth) make it unlikely. Thanks in advance for any advice or suggestions.
Re: OT..Need advice on installing 2x4 stud wall
Mac in Indy
>First since this is not a load bearing wall you have fewer constraints on it's construction.
Are you running the top plate parallel or perpendicular to the existing joist. If running parallel you are right the odds are against you hitting a joist. A toggle bolt or two wouldnt hurt but the construction adheasive should be sufficient. If you run perpendicular then a nail through the top plate into the joists you traverse will be sufficient.
Good luck! Some of those old houses can really throw you a curve (don't assume anything is plumb or square!).
Mac (amature remodeler having worked on my old house for 30 years)
Lee Ohmart
>I'm assuming from your comment on finding wood that the ceiling joists run parallel to the wall you plan to install. As long as it's sliding doors you plan to install, the toggle bolt/adhesive approach should work. If it's swing doors you are installing, that could be a problem if you have anybody who slams doors to express their anger. Do you have a stud finder or know someone who has one? I have found these to be a vast improvement over tapping the wall.
Dick Haley
>Thanks Mac, sorry for the late reply. Wall will be parallel with ceiling joists. Should not be much of a load but I was not sure.
Dick Haley
>Thanks for reply Lee,again sorry for late reply..was called out.The doors will be light weight bifold. I do have a stud finder and will do a complete search when I arrive in TN. I would feel better finding wood.
Gary Evans Tallassee, TN
>Hi Dick,
If you can spot your screw holes accurately on the top plate and the side studs for your new wall, I like those plastic togglers for sheet rock, rather than toggle bolts. The togglers stay put while you run a screw into them, plus I think they are somewhat cheaper than metal toggle bolts.
Gary
Dave Bair, Eaton Rapids, MI
>Why not solve the attic-access problem at the same time by adding an access opening in the ceiling of the closet? And, if you're going to do that, you can add the nailers and make it a more solid construction.
Dick Haley
>Thanks Gary...I will look into that,sounds like agood idea.
Dick Haley
>Thanks for your reply Dave. The attic access is going to happen.Have a spot picked out in center of home (small hall to bedrooms and bath). Need to overcome closet situation as quickly as I
can for lack of places to hang clothes(Did I mention Daughter!!).
Another possibility
Kent in Emmaus, PA
>You could frame a slightly dropped ceiling above the new closet, with 2x4s attached pependicular to the existing joists, then build the new wall under this "mini soffit". You'll lose a few inches of height inside the closet, but that's usually wasted space anyway.
Re: Another possibility
Dick Haley
>Thanks Kent..You have definitely given me something to consider. I would feel much better if I had something to nail to even though it appears the toggle bolts and adhesive will work. Thanks again.
I couldn't do it.....
>I couldn't put up a wall that was anchor to the ceiling with glue. Not for my daughters at least. Sure, it would probably be strong enough.... but....
I wouldn't be able to sleep at night.... thinking that the wall might fall over and hurt them. I know it would never happen, but I'd still worry..... daughters... you fathers know how it is.
Like previously mentioned, I'd build a lower ceiling, so I could have some 2x4 lumber nailed into the joists above, and the wall below.
Happy Woodworking!
Toney Robertson
>As has been said by others, since the wall is not load bearing your problem is not as great.
Lay out where your wall is going and chalk some lines ceiling, walls and floor. Take two 2x4's that are the entire height of floor to ceiling. If the house was constructed in the last 30 years each side wall will have a double top plate.
Screw each end stud of the new wall into the top and bottom plates of the existing wall with 2 or three 3" screws which should anchor your new wall securely. Take a couple of right angle clips (about three" wide with one leg about 3" long and the other one is about 1 1/2" long) that you can get at your hardware store.
Attach your top and bottom plates with angle clips and then fill in the rest of your framing.
If your new wall is very long (over 6 feet) you can screw your bottom plate down to the floor and probably glue the top plate to the ceiling.
Without glue this entire wall can be removed easily in the future if so desired. With glue the removal and repair will be harder.
PS. If I was you I would forget the toggle or drywall anchors.
What I would do
DB
>Remove the existing cieling where the closet is going. Start on the inside maybe 6" until you find where the joists are. Adjust the size of the closet if joist is close to where the closet is going. Make good straight and clean cuts. If needed put in some 2"X4"s between the joist and attache the wall to the 2"X4"s.
Re: I couldn't do it.....
Dick Haley
>Mark,my only daughter after three son's. You are not helping. I am 67 and she is 25 and wants some place to hang her clothes quick. Give me your best go at this situation...Dad!!!
Dick Haley
>Thanks Toney...especially about anchoring side wall.
