plastic wine corks make good little feet
Wayland
>Hi Gang-
Just wanted to pass on an idea, which is that the plastic wine corks that are used in some bottles of wine, cut in half (or even maybe in more pieces) crosswise make good feet for all kinds lightweight wood boxes, cabinets, etc. You can either mount them with a screw from the inside or glue them into a tight fitting mortise that you make with a forstner bit. Although I haven't tried the latter, it looks like it would work. The inside of the cork is made of a porous plastic that I think would take glue ok.
Better hurry to collect these corks though. Within 5 years, I expect all wine bottles to be closed with screw caps. In my opinion, the plastic corks will be seen in retrospect as a brief transition between more than a century of cork corks and screw caps.
Oh, and you might want to consider making a jig to hold the cork while you cut it in half with a saw.
Happy woodworking
Wayland
Re: plastic wine corks make good little feet
Gotta drink faster
