>Back in 2004 someone gave me a used Sony Camcorder. All it needed was a new battery. I purchased one from Radio Shack and video taped Hurricanes Francis and Jeanne. Total recording time about 2 hours.
Haven't used the camera since and would occasionally charge the battery. Haven't done it for 6 months or more so yesterday I picked up the camera and tried to turn it on. Nothing. Put battery on charger overnight and tried again. Nothing again. I suspect the battery is DOA.
Question- when not in use should battery be left on charge or on camera or just lay there?
It is a 6.0 volt 2700 mAh Nickel-Metal Hydride battery custom made for Radio Shack in China.
What did I do wrong besides buy something from Radio Shack?
>My understanding of the NiMH battery is that they will discharge when left unused..now whether that leads to battery failure I'm not entirely certain, but I can say that I've had the same experience....I have a couple Sony video cameras that I use in a pair of wildlife cameras for hunting and have the same issues when they are unused.....so I ended up purchasing some spare batteries from eBatts and an external charger.
You'll have to look into the archives here, but not long ago there was a thread about putting batteries that were discharged into the freezer overnight. This seems to bring them back enough that when returned to room temp, they will take a charge again. At first I scoffed at this,(like snipe hunting & cow tipping!) but decided I didn't have anything to lose with two batteries I had. Worked for one of them, and the other I think must have been shorted out internally. With all that said, you have nothing to lose by trying it!
And they discharge at a faster rate than other types of rechargeable batteries. Keeping one on a charger constantly is not recommended unless it is a trickle charger which will keep it topped up without damaging the batter. Overcharging is an enemy of batteries. Another bad thing is to leave a NiMH battery connected to a load during storage - this can cause permenant damage - remove the battery since many devices constantly use some power even when switched off.
Note that NiMH batteries that have been stored for a long time may recover after several charge/discharge cycles.
I'm not certain about NiMH but with the similar NiCad nickle-based battery chemistry cells left dormant can be internally damaged by "wiskers" growing and shorting the cells. We have repaired these in the past by zapping them with a high current (a discharge from a bank of large capacitors). To avoid deterioration of nickle-based batteries in storage, it is generally recommended to recharge them periodically, at least once a year.
Note that there is a huge amount of info on batteries on the internet (much of it contradictory!) The link below is one site with technical and mostly useful information. You can click on "Technical Resources" and then "How to Store Batteries" for some interesting reading.
