OT-Unfamiliar chimney
Kneale Brownson in sunny N. MI
>I'm installing a cold roof--a second deck on sleepers to provide full venting of the roof--on a rental that needed a new shingling anyway and has had a long history of ice dams despite numerous attempts to fix the problem.
As part of this project, I planned to get rid of this funky fake chimney:
This chimney had this on it for a cap:
The cap has a raised lip in the center that I assumed surrounded a typical gas appliance doublewalled/insulated chimney. Instead, when I removed the cap, I encountered this:
This thing looks to have a ceramic center, a band of cementicious material and an outer skin of maybe a paper product. Instead of the nice shiny metal surface I expected to find, I get this ugly thing.
I've already spent way too much money on the parts for the roof of this dwelling, so I really don't want to reinstall a complete gas chimney. Any suggestions for hiding this monstrosity with something other than that fake brick thing?
Re: OT-Unfamiliar chimney
Possible Asbestos Warning
>This looks like a product sold as Transite. The stuff you thought was paper is a product made of asbestos and cement and then rolled into a tube sort of like paper tubes. Either remove it completely or leave it undisturbed. Also, Look down the flue and see if it is still sound on the interior. There have been cases of the material failing and delaminating on the interior from the moisture heat and chemistry of the gas combustion fumes. If the interior is damaged, replace the flue.
If it is sound and you decide to keep it, you could build a chase around it and put siding on it. Keep it several inches back from the pipe and put a metal cap on it and then put the cap back on the flue.
Re: Possible Asbestos Warning
>Thanks, Barry. I wondered if the paper-like stuff was an asbestos product. The inner liner looks intact, but I'll use a flashlight to be certain.
I've done siding chases around masonry chimneys before, so that most likely will be my approach to eliminating the fake brick mess.
Kind of curious as to why you thought it might be
Don Henthorn
>a fake chimney. Looks like the real thing so there ought to be evidence of a fireplace a or a flu opening somewhere below. Of course it may be covered over.
Re: Kind of curious as to why you thought it might
>I meant "fake" as in nonmasonry but trying to look like masonry. It is a functioning chimney for the furnace and water heater. If it weren't, it would be in the dumpster already. I just expected it to be something like a metalbestos hiding behind the "fake chimney". Guess I should have called it a funky chimney chase, eh? If it stops raining long enough today, it'll be enclosed in siding material and I can get on with the stripping off of shingles when it stops raining tomorrow.
