Alder: rather soft, works easy, looks OK
Paul Dwight
>Alder seems to be a popular cabinet wood in the western states, maybe because native alder stands in the northwest are much closer to us than are the eastern hardwoods. From a hobbyist's perspective, alder has a couple of advantages: (1) it's not very expensive; (2) it works easily; (3) with careful finishing, it can be attractive. It can make a decent fake cherry, if that kind of thing interests you.
Disadvantages: (1) It's soft and dents easily. Much softer than cherry, for example. (2) From what I've seen in our local supplies here in Phoenix, long lengths of clear wide stock do not exist. A 6" wide board 8' long will usually have a couple of knots. (3) As George noted earlier, it is prone to splotching. Pre-stain conditioners work pretty well to control splotching. (4) I've never seen figured alder -- no curly alder, no spalted alder, no nothing. Maybe it's out there, but none of my local suppliers has it.
I use a fair amount of alder as a secondary wood -- for the back of a cherry cabinet, for example, or for drawer boxes that run on ball bearing slides. I also milled the interior trim for our home remodeling project out of alder. I don't use it as the primary wood for furniture anymore, mostly because I'm gravitating toward woods with more figure -- and also because it's softer than I like.
Hope this helps. -- Paul
