Stencil under finnish . . .
SteveM
>These paddles are childhood treasures (at least to me !) that Dad finally wanted out-oh-the-garage. I'm pretty sure of my method here but if I screw up these stencils I'd be crushed. There is, like, a LOT of coats of varnish and poly on them and I want to even out the surface then re-finnish with that glassy surface they have out of the store. I figure if I go with, about, 300 paper JUST UNTIL I get it smooth I should stay out of the ink. BUT this is my worry.The scratches will disappear with new poly right ? Right ? I'm PRETTY SURE. Just need a vote of confidence.
Re: Stencil under finnish . . .
Dick Coers
>Steve, I agree with your approach. The stencil seems to be well below the finish and I sure don't see any bleed of the ink into the finish. I doubt if you will get an even color as the finish will soak into the wood where there currently is no finish. The wood fiber will be slightly torn in those areas and not sanded smooth. The new varnish will really soak in there. Also the old varnish will be yellowed more than the new in those areas. But as far as I'm concerned, age/beauty marks.
