>I bought a 6" x 24" piece of that graphite sheet from Klingspors to build my edge sander. I ahven't used it yet, but it sure seems liek it's going to work well. When I looked at alot of the expen$$$ive large old edge sanders, that's the kind of stuff they used.
>That is what you want to use. I am not familiar with that particular tool, but that is what I use on mine.
Also, I would like to add, that I like using it around the nose of the opposite end of the drive wheel. If it has an idler wheel, this may be fine for keeping the belt running in circles, but they are not great for sanding the inside of concave curves.
I have an elliptical curve somewhat like the leading edge of a plane wing, or boat keel, which works great for sanding fair curves on the inside of shapes that are hard to get right otherwise. I use this much more than the straight platen, but then again I do a lot of curved work.
I get mine from Memphis Machine, which is an industrial supplier just about in the center of the country.
>I recently purchased a used Jet 6 X 89 edge sander. In addition to building a better base with mobility, I plan to install a graphite platen on the contact plate. I saw these listed in the Woodworkers Supply catalog; 3 for around $45 bucks I think.
For a really nice mobile cabinet, go to benchmark.com for a review and plans for the edge sander he has.
