All American Log Splitter *LINK*
Yonak
>I'm getting ready for wood splitting season. I have split all my wood my hand until now and, well, I'm not getting any younger, you know.
I'm wondering if any one has had any experience with this 12-ton wood splitter. It's pedal controlled and air assisted, I believe. It really doesn't look heavy enough to stand up on its own, but I'm only looking for a little assistance, not a machine to do all the work.
Re: All American Log Splitter *LINK*
Kneale Brownson in sunny N. MI
>I'd rent a real splitter for a couple days each year. You'll be money and back strain ahead.
Dale Lenz
Dale Lenz
>Look at the photo section very carefully, busting pine, does not show the man lifting logs on splitter. Smaller logs, maybe 12" in length, looks like cooking stove wood. My wood heater takes 18" wood. I'd look around more. Dale
JKJ in East TN
>Is 12-ton powerful enough? I use a 20-ton (I think) hydraulic splitter powered by a gasolene engine and while it's never stalled, it strains at times on very large or challenging pieces, for example some crotches and big chunks with strongly interlocked grain.
Something that looks undesirable about the one in the link is the apparent limited stroke length of the pressure cylinder. Perhaps not a problem if all of your wood is close to the same length, but if it's like mine the thing may require repeated readjustment during use.
Also, most vertical splitters have the cylinder at the top pressing downward, allowing a large chunk of wood to sit nearly on the ground. It looks like the one shown would require lifting and holding the wood in place which may be difficult or impossible for one person splitting large chunks.
Have you looked at the horizontal manual hydraulic sold by Northern Tool and others? $120 at the moment.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200316859_200316859
Dick Coers
>Unless you are only splitting small dia and clear stock, I would stay away from that machine. When I used to have a hydraulic splitter, sometimes I would have to get the ram almost to the wedge when I was splitting knotting stuff. Also the platform on the jack isn't too wide. I would suspect that large diameter stock would have to be held in place as the jack takes up the slack. I agree with the others, keep looking.
Looks Like a Teaspoon in Search of a Mountain
Pete in Holland, MI
>I think you'll be dissapointed with the perforamce of this "toy".
I looked into buying a decent gas powered splitter. Opted instead to let my pile of cut wood grow, then rent a splitter for $40-50 per night and split like hell for a night & split up my 5-7 face cords for the year. No big up front costs, and no equipment to store afterwards either for the other 364 days of the year. Have recently gained access from a friend's unit that can be "rented" for a 12-pack.
Word of caution though, once you buy one, don't tell your friends about it, else they'll be putting miles on it too.
thanks
Yonak
>Thanks for all the sage advice. I knew I'd get level-headed input from this group.
Re: By the way Yonak
Larry Clinton At Frankfort (Central)., Indiana
>Around here (Central Indiana) there are MANY good Gas engine log splitters sitting behind Garages and Houses. Seems there were a whole lot of people bought new wood stoves, Chain saws, Log Splitters, and in some cases pickup trucks to save money when fuel costs rose a few years ago. After a couple years of scrounging for wood, cutting, splitting, carrying, and cleaning out the stove (and house when the stove smoked it up), they decided it wasn't worth the effort. I have seen several splitters that cost between $1,000 & $2,000 selling used for $500 - in top shape. Might want to look around the neighborhood, check the ads, or even place a "splitter wanted" ad in your local newspaper. I burned wood as my only source of heat for about 7 years. I had surgery on my neck and couldn't do the work any longer so installed a new furnace and air. Course I'm just about too old to do it now anyhow, and many other things - just can't remember what they were.
JKJ in East TN
This is true. I chained mine to the barn and "lost" the key. "Sorry, it can't be moved at the moment but you can bring your wood and split it here" which never happens.
