Rubber rollers?
Rubber rollers?
Rubber rollers?
jeff
>Hi all
Does anyone know if you can sand rubber rollers to clean them up.
I tried cleaning and renewing the roller on my sander, but it needs more.
Its a large roller 5" diameter by 13" long.
I was thinking of putting it on a lathe and truing and sanding it to bring it back to usable shape.
Will this work?
And any thoughts?
Jeff
PS: Rick, my wife deleted your phone number before I wrote it down.
Call or email me your number.
Re: Rubber rollers?
Re: Usually grind thm to shape
Brian in Brighton
>Usually when I buy rubber coated rollers for various customers the outside diameter is ground to size. I am not sure of the type of grinding wheel used. You might want to do some searching for that. I doubt if a cutting tool will do the job as it will probably grab the rubber.
Brian in Brighton
Re: Rubber rollers?
Re: Rubber rollers?
Doug Turner
>I was at a tire retread factory once and they used a powered wire bristle wheel. This cuts rubber very fast.
Re: Rubber rollers?
Re: Rubber rollers?
Dale Stansbery
>I presume you mean cleaning and not shaping them. You might try Bleche White tire cleaner. It does a good job of removing dead oxidized rubber. Just use a good stiff bristle scrub brush with it.
Re: Rubber rollers?
What about surface cracks.
jeff
>The roller also has alot of crazing (surface cracks), and the oxidization.
I had hoped surfacing it (a small amount) would help it.
The rubber still seems to be pliable and usable.
Jeff
Re: Rubber rollers?
Re: Rubber rollers?
Pete in Holland, MI
>Your cutter on a lathe will dig into the rubber. It's too elastic to try to shear/peal cut. It needs to be ground with a coarse grinding stone/wheel.
If you have access to the technology, chilling it in liquid nitrogen will harden it enought to machine it though.
