Help-Tablesaw fence
Help-Tablesaw fence
Help-Tablesaw fence
John Ross
>Hello Everyone,
I am sure that this has been raised many times before, but with all of the new toys coming out, I may have missed something. I own a Powermatic model 66 tablesaw. I have never been able to get the fence to an .010 tolerance with the blade. I am using the factory fence and a TS alignment rig with a dial indicator. I have noticed shims between the metal and plastic parts of the fence. There are also allen-screws for adjusting it square.
My frustration is with the fact that I buy high quality blades and spend hours "tweaking" everything only to continue to burn cherry and maple. The closest that I've been able to get over the length of the fence is .050. I wonder if that's "good enough."
I would consider a new fence. Am I missing something or just being too picky and should just take off the burn marks with the jointer? Maybe the aforementioned Gripper will help?
Thanks in advance,
John
Re: Help-Tablesaw fence
Lee Schierer - McKean, PA
>You don't say what type of cuts are giving you burn marks and what type of blades you are using for those cuts. The use dedicated blades for crosscuts and rips will reduce the likelyhood of burning. Thin kerf blades for ripping may be needed if your saw is a lower Hp unit.
Hopefully you have first aligned the blade to the miter gage slot, then the fence to the miter gage slot. Attempting to align the fence to the blade will increase the chance of inaccuracies. You will also need to insure that he face of you r fence is flat. Undulations in teh face will also cause problems. The shims you mentioned may need adjusted to deleiver a dead flat fence face.
Also, the clamping mechanism for the fence has to be repeatable. On my Craftsman fence the fence lock would not always clamp square after it was moved. I replaced it with a Beismeyer fence and have not had that problem since.
You also need to feed the board through at a steady rate. Stopping, particularly on cherry, will likely produce a burn mark. If your saw bogs down then it is either underpowered, teh blade is dull or the wood is pinching the blade. Smaller saws (contractor models) will not always make burn free cuts on stock over 1" in thickness.
Lee
>Good Afternoon John,
I don't own a Powermatic 66 and wish I did. I operated one a couple years ago and it worked like a dream. Your saw isn't "close enough" if it burns cherry at a normal feed rate. My Jet Contractors Saw doesn't, and its not close to your league. If you can tweak it so that it doesn't burn, and everything alse seems effectively square then I'd say you can be happy with the performance. Otherwise, get help or replace the seemingly defective parts.
George
David Yoho
>I'd say your saw has enough power, given it's a PM66. It also sounds like your alignment is close enough. After all, we're talking about wood here, not metal work. I'd be inclined to look more at your blade sharpness, type, and feed rate. Cherry is one of those woods that burns easily when cutting or milling. Worst case, rip 1/16 over and clean up with a pass on your jointer.
David
Jim Dillon
>John,
You've got a wonderful saw and your tweaking sounds fine. But, as others have said, cherry and to a lesser extent maple are prone to burning. In my limited experience, once committed to making your cut, you must not stop or burning will likely result. Try to push your board through at a steady rate, not too fast or too slow. Some TS blades are more prone to burning. My 40-tooth Forrest-II seemed to burn more than I thought it should, especially after it had a few miles on it. I have a Forrest-II 24 tooth and that is better. In addition to tooth-count, I think it is also related, in part, to the clearance between the carbide tooth and the blade itself; some blades have more clearance and hence burn less. I have a Freud 24 tooth rip blade that does very well, but I still don't stop in mid-cut. Good luck.
Jim
Dan Donaldson
>Make sure if it is out, that the error is more toward the rear of the blade and wider there. You don't want the back end closer than the front. If it is, that could explain your burning as well as be a potential source of kickback.
Larry Marker in Alabama
>In addition to what the others have said, make sure the blade is clean. Pitch build up on a blade can cause burning.
I rip cherry on my Unisaw with a 24 tooth Jessada rip blade and have no burning problems.
Larry
Here's the drill...
>The first thing to do is to align your blade with your miter gauge slots. If you haven't done that, go back and do it now. On cabinet saws, there are four bolts that hold the top to the base. Loosen them slightly and tweak the top so that the blade (or better yet, a reference disk) is spaced evenly from the miter gauge slots.
Next, check your fence face for flatness and squareness to the table. You should be able to check it along its length with a machinist's square and have it be dead square all the way. A long straightedge -- preferably a decent quality one -- should verify the flatness of your fence. If you need to adjust or add to the shim stock between the UHMW fence material and the metal tubing part of the fence in order to make it flat, do so. You should be able to tweak the flatness to a couple thousandths with feeler gauges, but you don't need to be obsessive about it.
Now, put the fence on the saw and adjust the squareness to the table by adjusting the Allen set screws on the fence's head end. All you need to do is get it lined up with the miter gauge slot(s), since you have already aligned those parallel to the blade.
At this point, with a clean, sharp blade, steady feed pressure and a little luck, you should be getting glue-line quality rips in maple, cherry or whatever. The PM66 is a killer saw. Frank Klausz has one. I have one like it only bigger. You should not be settling for less than beautiful quality results.
Ellis Walentine, Host
Thanks for posting this.
JKJ in East TN
very good advice!
Mike Schwing from Md.
>In addition to all the other good advice, this one often escapes folks. Not only will it be safer with less chance of pinching, it will burn less. I tune my fence to be slightly further away towards the rear, too.
Good Post, just one more detail
Keith Newton
>If it is like my older PM 72, there is a rod that connects the back-rod clamp after the cam squares the fence, and clamps that end. If this adjustment is off, it could be clamping to the back too soon, which would make the fence be off in the direction that it was last moved to either side.
If this nut is too loose, the back of the fence may move away from the blade due to the pressure as you feed the work through even if you are setting the front just right.
Just a thought.....
>Ellis (and others, this subject comes up fairly often. COuld we get some of the better writers to write illustrated procedures for how to align your ...(fill in name of tool)...! These instructions wouldn't have to be brand specific in most cases. They could be lumped into one place like Other articles or a new category under articles & reviews.
Maybe I've had too much sugar today.
Lee
Re: Just a thought.....
Dan Donaldson
>The shop or power tool catagories would fit this. We would be happy to post articles like that if someone wants to take the time to write one. Pictures are great (just send the full sized ones, we can resize as necessary.) If you don't feel comfortable with your prose, just write it up and our esteemed editors will fix it up and format it for you.
We just got a bunch of articles in the pipeline, so watch for them soon. I encourage everyone to take a look at the articles. There are some very nice writeups on a lot of topics.
JohninRI
>I just want to say "Thank You" for all of the input. From what I've gathered, I think my problem lay with my blade, a Forrest, and sharpness and cleanliness. I recently changed the blade, but a friend cut a lot of cabinet grade plywood, while I was at work. Thanks for breaking me out of the box.
John
