(OT) Window glazing....HELP!
Eddie Pacheco, San Jose, Ca.
>I'm building a small storage shed along the side of our house and I decided to add some leaded glass windows, that I made, to dress the thing up a bit. (yeah, I have too much free time) I purchased some DAP '33 glazing paste and I am having a heck of a time getting a nice smooth finish on the stuff. The temp right now is 78 degrees F and I'm working the paste with the putty knife, but so far my efforts look like crap. I used an oil based primer on the wood early yesterday and the surface is clean. I'm thinking of scraping the stuff off and going to good old caulk for this job. The weather isn't too bad here and the windows are sheltered with a 6" overhang.
Any suggestion/pointers on what I'm doing wrong with this glazing paste? Do I need to work it more? Apply PAM to the putty knife?
TIA
Re: (OT) Window glazing....HELP!
Picture of the glass panel
>I wanted to give the shed an airy and dignified look...:-) The front and rear glass panels are the same. The roof is missing the drip strip along the side. I've been too lazy to go HD to get them.
Lee Schierer - McKean, PA
>Wet the putty knife with water or spray a little water on teh putty. It will smooth right out!
Lee
Re: Picture of the glass panel
>You might have problems putting the drip edge in after the shingles are in place. Normally the drip edge gets installed first and the shingles go over it and get trimmed back to the drip edge.
Lee
Drip edge
>Thanks for the help, Lee, I'll try squirting water on the putty knife. I was able to work it a little better when I went back to it after posting, but I'm still on the verge of scraping the stuff all off. What an ancient way of sealing glass and wood.
On the drip edge; I put the shingles on yesterday and I precut the two edge strips I bought in the parking lot of HD so that they would fit in the car, and I uh, uhm, went from memory on the lengths I needed. Of course I was too short. (yeah, yeah, where have I heard that before) I haven't nailed the shingles near the edges yet.
Ken Oakley-Sunny St. Cloud, Fla.
>When I did things like that I would wet my finger,(your choice--I had my favorite), and would smooth the compound with that finger by runnning it along the compound. WARNING--- DON'T LICK YOUR FINGER WHEN YOU FINISH !!!!
I'm only glad,....
>You didn't read my reply to Lee and post one of your comments. Thanks for the info.
Joanne Adler in Pt. Pleasant, PA
>Hi Eddie,
Last Fall I re-puttied all the windows on my shop--about 50 or 60 little panes (which makes one big PAIN!). Some I had to put in a new pane and use those little points to hold the pane. The putty worked easier when it was a little wetter, as has been suggested. I also got that special putty knife that has the V in it and is made for glazing. That helped and saved my finger from nicking it on the points that didn't seat all the way.
Grant in Iowa
>Eddie,
I grew up on a turn of the century farm, and maintaining equally old real-estate properties with that type of glazing compound. Here's how i do it:
-get a lump of the compound out of the can and work it like clay until it is warmed by your hands.
-Make the lump into a noodle about 1/2" in diameter by rolling it between your hands (just like making a snake out of clay).
-Place this noodle in the area it is needed and press it in place with your fingers. Make sure you have too much in the bevel. Do this all the way around the pane.
-Now, imagine a perfect miter in one of the corners, place the putty knifes end along that imaginary line, and with the knife flexed and held at a very low angle to the putty, draw it along the edge of the pane, holding the same angle. Yours looks like the knife is at too high of an angle to me. You'll get some squeeze out which can be cleaned up easily with a lump of the putty by dabbing and rubbing at the squeeze out.
Good Luck!
Grant in Iowa
Thanks Folks
>Wetting the putty knife helped big time. Thank you very much, Lee, for that simple tip.
Grant, I read that on the instructions on the container and sluffed it off. What a numbskull. This was a case of me thinking that glazing is so simple anyone can do it easily. I was wrong again.
Re: I'm only glad,....
>I try not to comment on the short comings of others. Old age has only brought some of mine to extremes. Ah yes, but there are the memories. But even they start to fade and wither.Glad I don't live up in the cold country.
Jason Roehl in Lafayette, IN
Done plenty of glazing in my career.
>And I hate getting that glazing crap on my hands, so I don't bother with the snake-making part. I just take the glazing knife and scoop out a glob, slap it in place, scrape off the excessive excess (gotta leave a little bit extra) and repeat until the whole run is filled. Then I go back and with a fair amount of pressure smooth it out as Grant described. When initially placing the glazing, I use a two-dimensional motion. If I'm glazing the bottom of a pane think of holding the knife vertically and scraping it off on the wood, moving from left to right at the same time as the downward motion.
I once painted the better portion of 162 windows on an old apartment building, including replacing 100 panes or so (some of the windows had 6 panes). The v-notch on the glazier's knife is for bed glazing--it goes on the frame before the glass in put in. At least it was someone else's responsibility to clean up the removed glass...can you say 'hammer'?
Jason
My wife's grandfather was an old time
Don henthorn
>carpenter and cabinet maker. He built many houses and much fine furniture. Early in WWII before I went to Europe he re-glazed the windows in my mother-in-law's house. He was really slick. He would take a glob of glaze in his hands and massage it to warm it up then holding the glaze in his left hand he would feed it to the putty knife in his right hand and in a single swipe would glaze a complete side. Clean, No surplus. With four swipes he would finish one window and it would be perfect. Unfortunately by the time the war ended and I was out of the army he was no longer working and being cared for by relatives in another state. I never got to talk to to him much, but he had so much knowledge and skill that you just don't find today.
