DC/ heat loss questions?
>Am I doing this right? My math and science skills are a little rusty.
There have been numerous posts on having the DC exhaust outside verdu inside. Mine is outside and I like it, but got to thinking about the heat loss/gain.
Looked up the Specific Weight of Air. It varies with temperature and other things, but at about 70 degrees (F) it weighs about .075 lbs per cubic foot.
So if I run my DC for five minutes and it is pulling 500 CFM, that's 2500 CF times .075 or 187.5 pounds of air. (I tend to run my DC in short bursts.) I am having trouble here, hard to visualize almost 200 pounds of air.
I looked up the Specific Heat of Air and It's about .25 BTU's per pound per degree F. (Sort of hard to find that number, apparently the rest of the world uses the SI system, Who knew?)
So, if the makeup air from outside is 15 degrees different that the shop air, 187.5 times .25 times 15 is about 703 BTU's.
There are a lot of variables here. Moisture vapor affects all of this, etc. Also, if the temp. out side is less than 15 degrees different that would affect as it would if it were more. I have a 1300 CFM DC, but I used 500 CFM as a Stab at the volume because I usually have one blast gate open on a four inch port at a time.
Just struck me as a lot that five minutes of DC could pull out (or in) 700 BTUs. I have a little window AC in my shop that produces about 8000 BTUH. If I were to run the DC for an hour it would pull 12 times 700 or 8400 BTUs. HMMM? Does this SWAG seem reasonable?
