200+ woodworking book reviews
Flex Shaft?
Flex Shaft?
Flex Shaft?
David Hammond, in Powder Springs GA
>I'm looking for a flexible shaft to hook up to my drill press, a drill, or even my lathe for variable speed, detailed sanding/buffing etc.
Anybody have any experience with either of these two - kind of big price difference, and I like the smaller keyless chuck on the more expensive one...
http://www.woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=116-753
http://www.eastwoodco.com/shopping/product/detailmain.jsp?itemID=11105&itemType=PRODUCT&iProductID=11105
Thanks,
David
Re: Flex Shaft?
Re: Flex Shaft?
Kneale Brownson in sunny N. MI
>I have one similar to the first one with a 1/4" capacity chuck. I've used it a number of times where I needed to drill but couldn't get a drillmotor into the spot. I didn't pay anywhere near what that one lists for, though. I don't know that a 3/8" chuck would be much of an advantage, because I doubt you could drill with a 3/8" bit. Too much torque required. For sanding/polishing, this should be just fine. If you have a dremel, they have a similar flex shaft.
