Questions on Rubbing out a finish.
>On advice gotten here, I went out and purchased 2F and 4F pumice, rottenstone, Paraffin oil, and felt blocks.
I have rubbed two pieces I shellaced. Pretty happy with the results, but I have a few questions.
I bought a felt pad for each grit. I am keeping each one in its own zip lock bag.
I wipe the piece thoroughly between each grit. The question is, is there still some contamination of the blocks? Do I need to clean them? If so, How? Do you clean the piece more than just wiping it? Do you use oil or solvent?
Is there a good book or video on this? (Finishing)
Another question. If you wanted to cover the shellac with another coat or you wanted to put lacquer or some other finish over it, how would you remove the oil and any residue of grit?
