Lacquer and ammonia based cleaners
Gary Camp Bend, Oregon
>I was having a conversation with Lisa this morning about table tops and cleanability. She mentioned the finish on the tables and chairs where she works always feeling "sticky". I asked here if they were using Ammonia based cleaners. She replied that they were using "Quat" sanitizer. I am assuming (and yes, I know what they does) they most, if not all they woodwork, tables and chairs where she work are Lacquered. Is catalized or pre-cat laquer affected by ammonia based cleaners like "old fashion" lacquers?
thanks
glc
Re: Lacquer and ammonia based cleaners
Plasticizers
>Michael Dresdner addressed this question a couple years ago on this messageboard, and it had to do with "plasticized" finishes -- more a description of the end result than the process itself. The way I understand it, most types of finish are subject to some sort of plasticization, whether through chemical or surface related causes. Maybe a trip back through our Messages Archive would find that thread. Otherwise, maybe Mike will pick up this thread and give you a more specific answer.
Sorry for the non-answer.
>"Quat." based cleaners are based on quaternary ammonium compounds. That is they have hydrocarbon chains attached to a central nitrogen. They are an ionic surfactant, usually in a water base. An example is benzalkonium chloride (which has a chlorine ion to "neutralize" the positive charge of the ammonium ion).
They are reasonable sanitizers. My question is, are they rinsing afterwards? If they are just spraying and wiping, they could leave a residue of the quaternary ammonium compound. This may leave a "tacky" feel on the surface, particularly on humid days when they can pick a little moisture.
>Quat has something to do with Quaternary. Look up or Google it. It has something to do with the new treated lumber. Its the Q in ACQ. One of the reasons for using ACQ was that quaternaries were well established as cleaners and disinfectants. Safe for humans and all that. Don't have any idea what this has to do with softening finishes, but the ACQ is very corrosive to metals, but that may be based on a galvanic reaction with the copper, Which is the C in ACQ.
Re: Plasticizers
>Thanks for the response, I'll search the archives
glc
>"Quat" as used in foodservice is generally a Quaternary Ammonium Chloride compound. There are sold as "no rinse" sanitizers. I've had a couple of restaraunts talk to me about refinshing tables because the finish is sticky. I think that I will suggest they try going back to a bleach based sanitizer, at least as a test.
thanks all
glc
