Need computer help
Need computer help
Need computer help
ben d.
>I have microsoft home xp with word perfect 10 and I cannot print anything that I write or receive that is in work perfect.
I can print Notepad, word pad or from anythings but cannot print word perfect 10.
Any suggestions for not computer literate person.
Re: Need computer help
Chuck W
>Are you missing an update for Word Perfect 10? Is it possible that you have a trial version that does not allow printing?
ben d.
>Computer is 4 or 5 years old and has always printed from word ok. Not a trial version. Have downloaded new driver and sometime it will print one time and some not but then not at all.
It was installed on the computer when I received it and have the disc that was sent with the computer. Did try and run the disc on top of the program but no difference in printing.
Don't use too often so don't really know when the problem appeared. Did get a new McAfee virus program that has a lot of clean-up on it and that may have been when the problem begain, I don't know.
Curt Harms
>I don't know if I remember the details but certain versions of WP after 8 up until 11 or 12 had this issue. You need to put a printer driver in the Windows startup fold as I recall. Just to try it, You could start the program manually. I don't know if I recall the name exactly but it was something like printserver100.exe or something like that found in the wordperfect program directory. There's a newsgroup found through Corel's web site that has information on this issue. I'm running WPX3 and haven't had this issue. I did have this issue with one version and I think it was WP10. When Corel went from version 8 to version 9 lots of things broke. It took 'em til 11 for things to work right. Still prefer it over Word.
HTH
Curt Harms
Re: Need computer help *LINK*
Larry Marker in Alabama
>In addition to the info Curt provided, you might check out the WP discussion on printer problems at the link below.
Larry
WP Printer Problems
Re: Word Perfect printing
Malcolm Timbers
>When you click on "print file" check to see what port the printing is being directed to, i.e., USB, serial printer port etc. Your printer may be connected to a different port. Or you may have got a new printer and it is trying to print to the no longer connected printer.
Lee Schierer - McKean, PA
>In older versions of Word Pperfect there was an internal to word perfect list of printers. Make sure the correct printer is called out and selected.
Lee
