Curio-Tempered glass - options
Dan Manturi
>I have been toying with the idea of building a rather large curio (maybe 2 of them) with mostly glass front and sides and shelves. I am told I need to use tempered glass for this for strength and breakage characteristics. I priced this casually and got some serious sticker shock. I recently built some french doors and used acrylic with great results, but do not think it would be that good for a curio.
Are there cheaper alternatives? It seems that buying one with tempered glass would be a lot cheaper than making one.. (yes, I know - "but it would be store bought...")
Opinons needed. Is it that pricey?
Dan M
Re: Curio-Tempered glass - options
Chuck W
>Dan,
How much were they quoting for the glass?
Ron Hildreth, Alta, Iowa
>Dan,
Suck it up, buddy! I've made several different cabinets and presently building a curio cabinet too. I've done extensive shopping for glass, and it's all pretty expensive when you get into tempered or 1/4" stuff. Around here 1/4" glass is nearly three times in price what the same size is for 1/8th".
Ron in Iowa
>My understanding is that tempered glass is in effect custom made for you. Once it's tempered they can't cut it. (It does its thing and cracks all to pieces) So they have to cut the piece(s) for you and then temper them and then package and ship them. (Years ago I got a number of pieces that arrived in a million pieces).
A couple of suggestions. Look at laminated glass. Like the windshield in your car, but they can cut it, so they may have a stock sheet they can cut down. Wired Glass is also available, but you might not want the appearance.
Another thought. Recent building code changes require safety glass in a lot more locations than used to be standard. So manufacturas have been forced to make windows with safety glass available and since it is a "standard" size and mass produced, the upcharge is relatively low. If there is a window manufacturer near you, you might be able to find one of their stock sizes that would suit you. You might have to design your cabinets to make the glass work, but you would at least have more options.
Don't forget to check out door lites also. You might be able to buy one that is Insulated glass and cut it apart and make two of it. Same for just buying a repalcement window sash. (Be sure both pieces are tempered.)
David Yoho
>Dan, if you end up going with tempered glass, better get used to the sticker shock. 1/4-inch is expensive, and as Barry already noted, can not be cut or altered once being tempered. Another thing most people don't know is tempered glass has a weak spot... it's pretty tough to break from a bang on its surface but hit any edge just right and you'll have a bunch of tiny pieces left.
David
Gary Camp Bend, Oregon
>Is laminated glass an option for you? I use it in place of tempered where code require one or the other. When it gets broken (and it will in my applications) you won't have a pile of pea sized pieces of glass. Plus lam can be cut at the local glass shop. At least for me, Tempered has to come from the big city, Portland, 165 miles away. It has to be cut, then tempered, then shipped. Check with a glass shop, lam my work for you.
glc
>Dan
You shouldn't really need to use tempered glass. I always use 1/4" plate glass as shelves and it's worked good for me. I have a kitchen cabinet that my wife wanted me to build that measures about 42"X 18", that has a couple plate glass shelves loaded with her stoneware. If you think stoneware is light, think again!
So far, not even a crack, and it's been hanging there for a couple years now. Here's a photo to prove my point;
Ron in Iowa
Dan Manturi
>Do not recall what it was when I checked last - I just said "wow" and let it go. I need to check again.
Dan
Dan Manturi
>I guess at this point I will price some 1/4" plate glass. I remember when I priced it, I even asked if there were stock sizes, as I would tailor my curio to those sizes and they said not really....
Thanks, all.
Dan
1/4" plate should be fine
John in New Mexico
>Though I only remember using that instead of 1/8" once in a cabinet that had 6' tall glass sides. Anything under about 4' x 1.5' we used 1/8th. When someone tells you "you have to use tempered" they're probably mis-quoting the IRC or UBC - there are no rules governing furniture. If you're selling the piece then its worth buying tempered for peace of mind regarding your potential liability, but thats about it.
John
Re: 1/4" plate should be fine
Dan Manturi
>Thanks, John. Not a question of "rules" per se, just what will hold up.
I am going plate glass on big surfaces, and triple thick regular on smaller ones I will get from a local stained glass supplier...
Thanks.
Dan
