Ok...about drill presses *LINK*
HC Sakman
>Any favorite ones out there? Any opinions on this DP linked below?
TIA
Chico...
Grizzly drill press
HC Sakman
TIA
Chico...
Grizzly drill press
Re: Ok...about drill presses
>I don't have this drill press, though I've used it at several classes that I've taken at the Folk School. We always set the angles using a "Bevel Boss" and an angle gauge.
It holds the angles well. We typically used it with small (3/8", 1/2" and 5/8") Forstner bits and spade bits. It didn't have any problems drilling through oak or maple.
You'll never use another drill press... *LINK*
Steve Strickland
>if you get one of these puppies.
http://www.grizzly.com/products/g8689
David Charters
>That looks just like my Central Machinery Drill press except I got mine for like $140 shipping included (and it came with a stand). it has been great (especially for my budget). I made a huge table for it, and it has been very nice to be able to drill into the center of such a big board. Not sure how accurate it is as far as wobble goes but that is because I have not done any really really precision work and it has always been fine for what I need. I was dazzled by the 16 speed presses, if they had a 42 speed one I'd think I needed that one, but the 6 or so speeds on mine have been plenty for small bits and big hole saws. Great drill press! I'll post a pic if anyone wants to see it.
David
>It depends on what your going to do with the Drill press. I've looked at those drill presses hard and would like to have one however 99 percent of the holes I drill are 90 degrees. I would want to make sure that this was easily resetable on that drill press. I wouldn't want to spend a good deal of time trying to get it back to zero all the time.
I make a fair number of stools from time to time so I simply built an angled wooden plate to hold them. (which dissappeared in the move) That is instantly repeatable and I never lose my zero setting.
Re: Ok...about drill presses *LINK*
Bartee (metro Atlanta)
>Chico, This will be my next DP.
After reading about Marty's big DP , the biggest thing I took away was the 1 1/2 hp motor. I want to be able t swing as large a forsner as I want.
Also the size and construction of the table looks really good to me.
I have a small bench top now. It's ok and I have used it alot, but it will slow down and not work on larger bits.
http://www.grizzly.com/products/G7948
Ron Hildreth, Alta, Iowa
>Chico,
I bought the floor model of the same radial drill press several years ago. I love it, especially when it comes to drilling compound angles, such as stool and chair leg holes on the under side of the seat. The only thing I think Grizzly could improved on is the depth stop- It's a little flimsy. I rebuilt mine to make it heavy duty.
Ron in Iowa
Re: You'll never use another drill press...
arw01
>That certainly is an interesting little beastie!
Somewhat in the market next spring if I am unable to fix the VS drill-press I have now. Myself I'm thinking I "need" the Delta 20" digital speed, digital depth, 2 way tilt table, blah blah blah.
Alan
Brrian Philipp
>I bought an old 1956 vintage, 3rd hand Shopsmith model 500 for under $300. Put in a new drive belt and pinion bearing. Then I put on new casters. Now I have a mobile drill press with adjustable speed at a touch, and a tilting table with fence. Also got the mortising attachement too. I also use it as a disc sander and drum sander, and on occasion as a lathe. Takes a little more floor space, but is a great combo tool. It makes a crummy table saw, so I have a Unisaw for that purpose.
Re: Ok...about drill presses - Hey, Ron
Carol - now in NC Nebraska
>I agree with Ron. I also got the floor model. And the depth stop is chintzy. But other than that it is a great drill press. Like all radial arm drill presses, when you have significantly extended the head you will have a little flex. But I don't do it often and I plan for it when I need to. I love its capability.
So, Ron, what did you do to upgrade the depth stop?
>Hi Carol! GOOD to hear from Ya!!!
Actually I just used a 1/4"X 2"X 2" piece of angle iron, cut one side so the piece more closely resembles the original, drilled the required holes and I was back in business! The piece is just thicker, therefore beefier.
Wish I could take a photo of it right now, Carol, but my digital Sony camera is in the repair shop. I've been having some problems with it.
Ron in Iowa
Thanks guys...So..
HC Sakman
>...really, what did you do to improve the depth stop Ron? Is that black collar around the quill, plastic?
Chico...
Re: Thanks guys...So..
>Chico,
The only part on the front of the DP that is plastic is the switch housing. The "colar" around the quill is part of the depth stop, and actually is the best part of the stop, made of cast iron I think, possibly aluminum (hard to really tell, as it's painted black). This is what the vertical scale is mounted to. But that's were the "overbuild" ends, because the factory just bolted a flimsy piece of 1/8th" angle to the side of the machine that the scale protrudes through, and it's pretty flimsy, but not hard to fix. The scale is threaded, and has a couple of nuts that you simply turn down or up to the quill height you want.
My problem with it is that during the heat of a drilling operation, I figure I was lucky enough to pick a dull bit, so give a little more pressure to the feed lever to finish the job, only to realize I was agianst the stop and now I've bent it!
Ron in Iowa
Re: Chico:
Jim DeLaney, Austintown, Ohio
>Chico,
I have the Shop Fox variant of that press. Mine's the floor model.
Like Ron said, it's a good drill press, except for the depth stop. I replaced the thin sheet metal 'angle' with a piece of 3/16" thick angle iron; reset the depth screw to read correctly with the thicker angle piece, and that's it. The whole job, including drilling and hacksawing the angle iron took maybe half an hour.
Although I don't need to use it often, I've found the angle adjustment, and also the long reach, to be very handy. Also, it has a positive stop for returning to vertical drilling. Makes it easy to realign.
When I don't need the extra reach - and its inherent flex - I generally keep the quill about ten inches from the post, making it a more or less 20" DP in 'normal' mode.
>Thanks, Ron. I got the idea.
