garage floor covering
Josh in VA
>Well I am in the final stages of my shop before I can move in. I will hopefully paint tomorrow, with the last thing being what to do for the floor.
The garage/shop is a 4" slab with a 2' knee wall. As of right now, I have no clue what to use for my floor. I will work mostly from rubber mats, but would still like something for the floor.
I have had a few people recommend the epoxy coat stuff you sprinkle the flakes in, but I have also seen 2 other instances where the stuuf did not hold up any more than a year. So I have ruled that out.
I will likely go and talk with a concrete guy and see what he recommends.
What have you used for your floors that has held up well?
Thanks in advance...
Re: garage floor covering
>3/4" T&G Advantech on 5/4" PTSYP sleepers 24" OC w/ 1" EPS between the sleepers, all over a heavy poly vapor barrier. Warm in winter and easy on the feet and knees.
Clint
Sean Troy
>Cure and Seal 20
Peter Gregory
>I don't know what Clint's sequence of letters mean, but I put 3/4" plywood, over pressure treated sleepers, over waterproof sheets you put under plastic floors, over a sealed concrete and was very happy with it.
My feeling is the Epoxy and sprinkles is a passing fad from HGTV, and not a great strategy for woodworking. I think if you were rebuilding cars, the epoxy solutions sound better.
Re: Kind of disagree
Larry Clinton At Frankfort (Central)., Indiana
>I have the Rustoleum epoxy - with the sprinkles - in my 30 X 30' shop. I have had it down for 2 - 3 years. I have had absolutely no problems with it. It is not "slick", I can spill and clean up glue, shellac, lacquer etc. without damage. I have all my equipment on mobile bases. These include my Unisaw with all the extensions, my 8" Grizzly Joiner, 20" Yorkcraft planer, and other heavy units. The Epoxy doesn't cut or scratch when these are moved. I can (and have) pull in a car or truck to work on without any problems. (I don't use it for a garage, but my son occasionally works on his or my vehicle in the shop as I have central heating and air conditioning, large air compressor and most all air wrenches needed). I would use the same material again. I have some mats in place by the lathe etc. to stand on.
Re: I agree with Larry
albertabob
>I have had the Rustolem product down in my warehouse for almost 20 years. It wont wear out. My brother put it in for me before Rustoleum bought the company. The stuff can be parged up the walls with a thicker consistency so the entire room becomes water proof.
Wood floors are nice too but I would not have placed concrete where I was going to cover it with wood.($$$) Wood makes a difficult floor to move heavy equipment around.
p.s. spend some decent change on some good work shoes and the floor problems will disappear.
Bob
'nother favoring epoxy
paul in AZ
>I have had Rustoleum epoxy floor down for about 2+ years. Moving stuff around on rolling bases or even dragging heavy items [like my planer or bench] that don't have wheels hasn't even scratched it.
I didn't use the sparkles but sprinkled a very light amount of the 'sand' [silica?] they sell for traction -but not enough that sweeping up is hard.
The only PITA is the prep. I did carefully follow the prep directions. Maybe those with peeling etc. didn't prep the concrete properly. Once prepped, get a roller on a pole and work fast. Believe what they say about working time.
Its a great floor.
For cushioned standing, I got some interlocking foamy rubber pieces totalling about 4X4 feet for less than $10. Try Costco. One by the bench and one by the bandsaw makes comfortable standing.
Re: OK to defend your choices, but...
Peter Gregory
>If you are going to have a shop, have a wood floor. If you are going to have a garage, warehouse or factory, do concrete. Concrete is a distant second best for a shop though. The reason that many people have concrete is that it comes with the building. No choosing, it is already there. Dropping sleepers and plywood on it makes sense.
I certainly agree that you should seal concrete and that the epoxy products work great, but man, it is so hard on your body.
True confessions, my shop floor has a few dings in it. There is a spot where I dropped a monster hunk of cherry, a couple of drips from the glue up of my workbench and a trail where I moved my bandsaw a few feet, but I kind of like the dings. They add character.
Josh in VA
>Guys thanks for all of the input...still undecided.
I would love to install a wood floor, but we do not plan on being in this house forever. I built it with 2 garage doors so it could be a selling point for guys who like to work on cars, yet can still be a functional shop.
As far as the epoxy coat, it was my first choice when I started the shop, and then I started talking to friends who used it. Out of 3, only one has had success. The two who had it fail are both machinist and there are paths worn around their shop. Hence my hesitation with the stuff.
Thanks
>I never figured out why people say concrete is so much harder on your body than a wood floor. I have had both hips replaced, not sure what caused the problem, Doctor said it may have been the steroids I had to take for a neck injury, (splinter on the spine removed by surgery - caused by an accident). I had worked on concrete all my working life in various industrial plants. I always found the shoes I wore were a BIG factor in alleviating the shock of walking on any hard surface. I still purchase very good, shock adsorbing shoes. Kind of like carrying a rubber mat with you and setting it everywhere you stand or step. I did have the choice of flooring when I built my shop. I didn't chose concrete due to cost, actually think it cost me more than a wood floor would have. I chose it as it is durable, and will support any machine I choose to place at any location in the shop. It also allows me to move those machines easily without worrying about damage to the floor. After 3 - 4 years of use and evaluation, I would still install concrete (and use the epoxy coating).
Ken Garlock, Collin County Texas
>Hi Josh.
Back in 2002 we built our new home. The painter said that the only coating he installed on concrete was Sherwin Williams Tile Clad II oil-based epoxy. We have it in a 3 car garage at the house, a two car garage adjacent to the shop, and in the shop. In five years, it still looks great with two exceptions. 1) One time when filled a car battery, I let some battery acid spill onto the floor. It didn't peal or loosen the paint, but it did stain it. 2) In the shop I have managed to drop hammers, and the like, that left little chip outs in the concrete. The paint remained on the chip. The Tile Clad came in two one gallon containers, parts A and B. They were mixed equally to give a total of 2 gallons of coating. The cost back then was about $80 for the 2 gallons. That is comparable with the cost of good quality paint.
Recently, S/W has moved to an eco-friendly version that they call Fast Clad.
The secret to a good epoxy coating is a clean surface. This involves a power washing, an acid cleaning, and a good rinsing. And rinsing again.
Good luck,
Ken
Re: Good Grief!
Peter Gregory
>You aren't sure if concrete is harder on your body then wood floors? OK, if you say so. 11:00 PM and you got me shaking my head. Wow.
