Best light questions
>Other than good strong sunlight, what is the best light for picking up defects in surface of the wood?
I have lots of fluorescents in my shop and I am beginning to think they throw sort of soft fuzzy light and tend to disguise sanding defects. At least until I put the first coat of finish on. The finish surely does not hide anything, it reveals all your mistakes. And each coat just reveals a new set. Or it could be that my eyes are failing or perhaps my standards have gone up. Anyway, I think I need a really strong horse light for the final inspection. Any suggestions?
Re: Best light questions
>A clear lightbulb or small quartz halogen bulb. The smaller the light source the harder the shadows. I use one of the clear lights with no frosting. The filaments cast a really hard light. small quartz lights do also but they produce a lot of heat and right now it's quite warm in my shop.
Flashlight
Ed Mulligan, Cape Cod
>I use a mini-mag flashlight. Hold it right on the surface so the beam creates a raking light. Also good for lighting up dark corners in bureaus etc. I usually leave the overhead fluorescents on but the effect is more pronounced if you turn them off.
Ed
OK, A flashlight question?
>The latest thing in flashlights seems to be the LED ones. They have from one to 6 or more LEDs and seem very bright, but there is something odd about the light. It seems grey (?) or blue and sort of fuzzy again. Or is it just me? How do they compare to he halogen lights?
What you need is...
>... glancing light. Get a cheapo construction lamp with a 500w quartz halogen bulb and set it just above the level of the surface you want to examine.
I had a design for an oblique lighting fixture that had two 12-v acar headlights in a plywood box on a stand. The whole rig ran on a 12-v. transformer. Sounds like this might be just the thing. Overhead light is lousy for judging surface quality.
Re: OK, A flashlight question?
JKJ in East TN
>The color of light from LEDs is certainly different than the broad spectrum from incandescents. The holy grail is white daylight which may never happen due to the way the light is generated, but with new phosphors they are getting better. Most have a distinct bluish cast.
BTW, I bought an LED bulb made by the Mag-Lite people to substitute for the tungsten bulb in their big 4-cell model. It's turned out to be my favorite light and after months of daily use (several trips to the barn every night) the batteries are still strong. A warning - my first LED replacement experiment for Mag-Lite was a cheaper 3rd party offering which turned out to be horrible in brightness, pattern, and color.
