Avoiding snipe Questions.
>I have a Dewalt lunchbox planer. I think the head lock may have some wear and could be a little looser than it was when new.
My usual approach to avoiding snipe has been to run long lengths and then cut smaller parts out of them. Also I try to cut pieces long enough that I can trim the ends off and cut away whatever snipe was there.
I was wondering if there was a better way? How about running some sacrificial pieces through the planer at the same time. Just some narrow sticks that are three inches or so longer than the work piece on both ends? Do the sacrificial pieces have to be double stick taped or glued to the work pieces?
I just made a table top and did not have enough wood to rim off the snipe. That's what drove me to ask.
Re: Avoiding snipe Questions.
Easy
HC Sakman
>Lift -slight upwards tension by hand- the lumber from the end of it as it exits the planer, especially closer to the end of the cut. Good idea to clamp or bolt down the planer though.
Chico...
NickB
>A couple of things, if you don't do them already:
Adjust the ends of the infeed/outfeed tables to flex the stock upward slightly; and
Lift the back end (as you feed in) and front end (as the stock exits the planer) of the stock as you feed it.
I have an older DW lunchbox planer (733), and both things help (although I do sometimes get snipe even when I do this). The key is to not let the feed rollers push the front/back end of the board into the cutter head as it enters/exits the machine.
I've not had particularly great success with the feeding the sacrificial stock through, in part because it seemed like I was pretty much guaranteed to have a timing problem as a key piece of stock went in/came out, producing significant snipe (maybe that's just me).
My General 180 doesn't seem to snipe-of course it weighs something like 8x what my Dewalt weighs...
Hope this helps,
Nick
Additionally...
HC Sakman
>I would not recommend to feed two different pieces of wood in these type of planers unless they're under 1" square for trim or something. Also, what I just described previously, allows you to plane as long boards as you wish.
Chico...
Neal in San Jose
>One successful method is to run all of the stock thru end to end. Jamb the next piece up tight against the tail end of the one already going thru and keep pressure on it until the planer grabs it. If the pieces are narrow enough, you can overlap them; send one thru and when it is about half-way thru, send the next one beside it and so on. It really helps to have an assistant, or at least an outfeed table with either of these methods. A sacraficial piece run next to the work piece will also work if you are only doing one piece. I've never had to tape things together. With my DeWalt, I usually only have enough snipe that I have to worry about it at all for the clean-up pass on each side.
>Same Here Neal,
My DW 733 is pretty good about snipe: hardly any at all, and that can be cleaned up with one shallow pass. Most of the time I don't have any snipe I can see. To me its a non-issue.
George
Or do like Chico...
Charles R. Smith from Victoria
>and get an expensive, European-made machine that does perfect planing. Except, unlike Chico, you should get them to deliver it with the right motor and controller. :)
Charles (who still suffers from sniping)
Ray Thompson - Middletown,IN
>Couple of ways to salvage short boards. Sacrificial stock ahead of and behind your keeper, overlap 2-3 inches. I have also used hot melt glue to put a half inch sacrificial piece on each side 4 or so inches longer than the keeper. I would say I have used the latter technique to run very short pieces through but somebody would tell me that it is unsafe so I won't. Might stand to the side, not behind or in front of the planer, just in case.
Ray
Keith Newton
>Barry, All of the suggestions above are good, like lifting both in or outfeed ends, and or jamming the next one into the back of the front one, and having the outfeed table slanted upward to take care of the lifting for you.
But most of the smaller planers have a thin sheet-metal bed, that could get some shavings under it, and make it more springy in the middle. If this is the case, that plate would push the work up as it comes out from under the front feed roller worse than would be normal if it was tight down against the sub-bed.
If you raise the cutter-head up enough to get your hand in there, you can probably tell just by pressing down with your fingers and seeing if it flexes, or feels tight. Usually you can just loosen a few screws to remove the wear-plate.
Very careful here! Danger!
Denis Ch�nard, Orl�ans, Ont.
I did that years ago with my Old Delta 22-540. Planer on the floor, and overlapping pieces to avoid snipe (and make the procedure go faster). I found out the hard way that planers can kick back...
One piece was probably a bit thicker than the other, and when it reached the outfeed roller, lifting it up a bit, the first board got freed from roller pressure and shot back at me, right on the top of the big toe. Let's just say that if the planer had been on a bench I might not have been able to bear children afterwards... From the marks on the board it was expelled at 60 MPH. I thought I had broken my toe...
Overlapping is OK with big planers that have segmented infeed rollers. Not with lunchbox ones.
DC
Portable planer short coming!
Lee Schierer - McKean, PA
>Most portable planers have sheet metal tables that will deflect (bend) when a weight is placed on them. When a longer board is put in the table sags slightly and snipe occurs. You can try lifting but you have to guess how much the table sagged and still end up with snipe when you for get.
What I did was to make a stand for my Delta Lunch box planer so that I have a wood in feed and out feed table in addition to the metal tables that came on the planer. I see less than .005" of snipe if any at all. My in feed table is 18" longer than the planer tables and the out feed is 30" longer so I don't have to catch boards.
Lee
