200+ woodworking book reviews
glue help
glue help
glue help
tom chapman
>i am glueing up a 4' x 8' table top for a kitchen table . i plan to glue 3 sections and then glue the three together . my concern is it is hickory . do i need a special glue or should i use some type of epoxy ?
thanks
tom
Re: glue help
Dale Lenz
Re: glue help
Dale Lenz
>I've worked and glued hickory several time, although never a 4x8 chunk. I've always used regular Titebond and have not had problems.
Re: glue help
Re: glue help
Jim Dillon
>Tom,
I made the exteriors of my kitchen cabinets from hickory and just used Titebond II and they are still hanging together after 5 years. I've never heard of any problems with hickory. Good luck.
Jim
Re: glue help
Glue-up process
Dave Bair, Eaton Rapids, MI
>Your idea to glue the top in segments is smart. May I suggest, though, that each sub-glue-up be narrow enough to run through your planer. Plane them down until all the joints in each segment are level. That way you'll only have 3 joints to level after the final glue-up.
